[SOLVED] Converting minutes into hour
Alright, stop fiddling with profiles if you don’t want to change the Items state.
Apply the transformation to your Item’s state presentation pattern metadata. (Most of the docs are still OH2 and describe the same thing using in the Item’s label.)
This thread is relevant for that -
