Javascript transform function to change the number
of minutes of CPU time from the System Info Binding
into a more readable format
eg: 2365 into '1 day 15 hours 25 minutes
The item in the items file is defined as follow:
Number LocalComputer_Cpu_SystemUptime "[JS(CPUTime.js):%s]"
and linked via PaperUI to the System uptime channel
of the System Info Thing
(function(i) {
if (i == 'NULL') { return i; }
if (i == '-') { return 'Undefined'; }
var val = parseInt(i); // The value sent by OH is a string so we parse into an integer
var days = 0; // Initialise variables
var hours = 0;
var minutes = 0;
if (val >= 1440) { // 1440 minutes in a days
days = Math.floor(val / 1440); // Number of days
val = val - (days * 1440); // Remove days from val
if (val >= 60) { // 60 minutes in an hour
hours = Math.floor(val /60); // Number of hours
val = val - (hours * 60); // Remove hours from val
minutes = Math.floor(val); // Number of minutes
var stringDays = ''; // Initialse string variables
var stringHours = '';
var stringMinutes = '';
if (days === 1) {
stringDays = '1 day '; // Only 1 day so no 's'
} else if (days > 1) {
stringDays = days + ' days '; // More than 1 day so 's'
} // If days = 0 then stringDays remains ''
if (hours === 1) {
stringHours = '1 hour '; // Only 1 hour so no 's'
} else if (hours > 1) {
stringHours = hours + ' hours '; // More than 1 hour so 's'
} // If hours = 0 then stringHours remains ''
if (minutes === 1) {
stringMinutes = '1 minute'; // Only 1 minute so no 's'
} else if (minutes > 1) {
stringMinutes = minutes + ' minutes'; // More than 1 minute so 's'
} // If minutes = 0 then stringMinutes remains ''
var returnString = stringDays + stringHours + stringMinutes
return returnString.trim(); // Removes the extraneous space at the end
})(input)
Thank you. Personally I`m not very familiar with transform at the moment, assuming will need to create new transform file or perhaps add to the exist one ?
This is what I can see in transform folder right now. Should I copy this script from above and paste it inside en file ? How would I integrate it with my item then ?
No, for each transform you will make a new file. ilename of your choice, the .xxx extension tells thesystem what kind of transform, since there are several.
You might choose minstohours.js for example.
A transform can be shared by many Items that you want to process in the same way.
So I did created the separate file called minstohours.js
I renamed my item definition to
Number MyDevice3_Time_Day "Total Runtime Today [JS(minstohours.js):%d]" <line-increase> (Restore)
Is the restart of OH required at this point ? Still seeing time in minutes at the moment so probably made mistake somewhere along
EDIT: I tried restart minute ago but that didnt made any difference. Looking at the log file can see the following info, its complaining about this .js file for some reason.
Caused by: java.io.FileNotFoundException: /etc/openhab2/transform/minstohours.js (No such file or directory)
at java.io.FileInputStream.open0(Native Method) ~[?:?]
at java.io.FileInputStream.open(FileInputStream.java:195) ~[?:?]
at java.io.FileInputStream.<init>(FileInputStream.java:138) ~[?:?]
at java.io.FileInputStream.<init>(FileInputStream.java:93) ~[?:?]
at org.eclipse.smarthome.transform.javascript.internal.JavaScriptTransformationService.transform(JavaScriptTransformationService.java:70) ~[?:?]
I have recently upgraded to OH 2.4. Looking in the log file I can see many warnings related to my javascript transform function converting minutes into hours/days.
2019-07-02 23:31:46.068 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state '85.0' on item 'MyDevice4_Time_Day' with pattern 'JS(minstohours.js):%d': Cannot format state '85.0' to format '%d'
2019-07-02 23:31:46.079 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state '240.0' on item 'MyDevice1_Time_Day' with pattern 'JS(minstohours.js):%d': Cannot format state '240.0' to format '%d'
2019-07-02 23:31:46.090 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state '0' on item 'MyDevice5_Time_Active' with pattern 'JS(minstohours.js):%d': Cannot format state '0' to format '%d'
2019-07-02 23:31:46.093 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state '85.0' on item 'MyDevice2_Time_Day' with pattern 'JS(minstohours.js):%d': Cannot format state '85.0' to format '%d'
2019-07-02 23:31:46.096 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state '11.0' on item 'MyDevice5_Time_Day' with pattern 'JS(minstohours.js):%d': Cannot format state '11.0' to format '%d'
2019-07-02 23:31:46.106 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state '240.0' on item 'MyDevice1_Time_Day' with pattern 'JS(minstohours.js):%d': Cannot format state '240.0' to format '%d'
2019-07-02 23:31:46.153 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state '0' on item 'MyDevice5_Time_Active' with pattern 'JS(minstohours.js):%d': Cannot format state '0' to format '%d'
2019-07-02 23:31:46.170 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state '11.0' on item 'MyDevice5_Time_Day' with pattern 'JS(minstohours.js):%d': Cannot format state '11.0' to format '%d'
2019-07-02 23:31:46.200 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state '240.0' on item 'MyDevice1_Time_Day' with pattern 'JS(minstohours.js):%d': Cannot format state '240.0' to format '%d'
2019-07-02 23:31:46.209 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state '0' on item 'MyDevice5_Time_Active' with pattern 'JS(minstohours.js):%d': Cannot format state '0' to format '%d'
2019-07-02 23:31:46.213 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state '11.0' on item 'MyDevice5_Time_Day' with pattern 'JS(minstohours.js):%d': Cannot format state '11.0' to format '%d'
I can see that things has changed in new OH version, so was expecting some teething problems at the start. Would you be able to tell me if I need to changing anything on my script to get it working as I can`t figured that out yet.
I’ve only just realised that your JS returns something like "2 hours 10 minutes", which certainly is a string and won’t format nicely using %d for decimal number.
I was worrying it was some regression bug, but in fact it’s an enhancement to report instead of failing silently. Luckily it just passes the whole string along despite failure, I guess.
Hi , this minstohours.js work perfect thanks ! , but i want to know if whe can cast the result in a rule ?
for exemple my Item is :
Number StartTimeRuntimeMinutesHuman “Alarm cuisiniere StartTime Minutes Human[JS(minstohours.js):%s]” and work perfect in the sitemap.
There is a way to call the result of : minstohours.js directly in the rule ?
Actually this is what i find to say the minute past… say(“Cuisiniere Allumee depuis”+ ((StartTimeRuntimeMinutesHuman.state as DecimalType).intValue ))
this work for Minutes but not for Hours …or i cast 61 minutes…not 1hour and 1 minutes like in the sitemap
Hello all,
I 've the same problem, using Openhab3
In took the javascript code and put it into the transform directory.
If I used the wrong datatype, I get an error in the log file. So, it’s working.
But: Nothing happens in the item view, there I have still the same display than before ( minutes )
And the widget also shows no difference.
I do not know, how to access the return key of the javascript.
I searched in the documentation, but I didn’t find a solution…
