Hi All,
first of all, I’m not a coder so what I’m doing is a lot of trial and mostly error ![]()
anyway, to set the scene of what I’m trying to do: I have some blinds without a position feedback. this means that I’m trying to maintaiN. virtual position by keeping track off the run time up and down and from there calculating a new run time (up or down) based on the homekit target position.
I have 2 items per blind one linked to homekit and one linked to my thing.
the problem I now have is the runtime variable is not working what ever I try. the rest of the rule works fine if I had code the runtime values.
rule “Blindsl”
Item bl changed
var delta = (Blindsl.state as DecimalType) - (bl.state as DecimalType)
var runtimeup = Math::round(5 * 0.5).intValue
var runtimedown = Math::round(5 * -0.5).intValue
logInfo(“default.rules”, "Delta: " + delta )
if (delta > 0) {
Blindsl.sendCommand(UP)
createTimer(now.plusSeconds(runtimeup))
logInfo("default.rules", "Timer finishes")
Blindsl.sendCommand(STOP)
logInfo("default.rules", "Timer activated" + runtimeup)
else {
Blindsl.sendCommand(DOWN)
createTimer(now.plusSeconds(runtimedown))
logInfo("default.rules", "Timer activated " + runtimedown)
Blindsl.sendCommand(bl.state)
it takes the blinds approximately 50 second for a full up or down.
but if I replace the 5 in var runtimeup = Math::round(5 * 0.5).intValue with delta which is the variable indicating the distance to travel from current to new position then I get the following error.
2021-01-03 14:05:27.240 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘Blindsl’: An error occurred during the script execution: Could not invoke method: java.lang.Math.round(float) on instance: null
your help is much appreciated!!!
ps apologies if I haven’t followed the forum rules in terms of highlighting code or other requirements. I’m pretty new in all of This stuff.
