[SOLVED] Cron with Day stopped working
I hear you :slightly_smiling_face:, but my point was that if something is broken in this area, there is no way to fix it, because it does not exist any more. Windows 3.1 still has bugs too!
The UI editor in Paper UI is not so good. Scripted automation is very good. Scripted automation with the helper libraries is great. Soon, these will be available to install through Paper UI…
But you can manually install too…
If you post a rule, I will migrate it to Jython for you!
