It looks like the CT100 thermostats are a bit unique in that they don’t have heat / cool setpoints. My guess is I am missing a transform or something.
http://10.71.129.3:3480/data_request?id=user_data&output_format=xml
<device id="22" device_type="urn:schemas-upnp-org:device:HVAC_ZoneThermostat:1" room="0" id_parent="1" embedded="0" disabled="0" device_file="D_HVAC_ZoneThermostat1.xml" impl_file="" altid="13" ip="" mac="" time_created="1440284089" category_num="5" subcategory_num="1" pnp="2126" manufacturer="RT" model="CT100" name="Basement Main" device_json="D_HVAC_ZoneThermostat1.json" local_udn="uuid:4d494342-5342-5645-0016-000002169ca2">
<states>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="Capabilities" value="210,156,0,4,8,6,L,R,B,RS,|32,49:2,64:2,66,67,68,69,96:3,112,114,128,129,133,134,135," id="0"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="ManufacturerInfo" value="152,25601,263" id="1"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="VersionInfo" value="3,3,28,9,1" id="2"/>
<state service="urn:upnp-org:serviceId:TemperatureSetpoint1" variable="ReportMode" value="S" pnp="*1.7.649*" id="3"/>
<state service="urn:micasaverde-com:serviceId:HaDevice1" variable="Configured" value="1" id="4"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="NodeInfo" value="20,31,40,42,43,44,45,60,70,72,80,81,85,86,87," id="5"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="SetPointInfo" value="H1,C1," id="6"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="MultiChEndpoint" value="2,0,1" id="7"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="MultiChCapabilities" value="1,8,6,49,133,2,8,6,49,133," id="8"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="ConfiguredAssoc" value="" id="9"/>
<state service="urn:micasaverde-com:serviceId:HaDevice1" variable="ModeSetting" value="1:;2:;3:;4:" id="10"/>
<state service="urn:micasaverde-com:serviceId:HaDevice1" variable="LastUpdate" value="1440284104" id="11"/>
<state service="urn:micasaverde-com:serviceId:HaDevice1" variable="FirstConfigured" value="1440284104" id="12"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="Neighbors" id="13" value="1,2,3,4,6,7,9,10,11,12,14,15,16,17,18,19,"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="LastReset" value="1440284103" id="14"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="AssociationNum" value="1" id="15"/>
<state service="urn:upnp-org:serviceId:TemperatureSensor1" variable="CurrentTemperature" id="16" value="73.0"/>
<state service="urn:upnp-org:serviceId:HVAC_UserOperatingMode1" variable="ModeStatus" id="17" value="AutoChangeOver"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="TemperatureScale" value="0,1,1" id="18"/>
<state service="urn:upnp-org:serviceId:TemperatureSetpoint1" variable="CurrentSetpoint" id="19" value="72"/>
<state service="urn:upnp-org:serviceId:TemperatureSetpoint1" variable="AllSetpoints" id="20" value="72.000000,72.000000,72.000000"/>
<state service="urn:upnp-org:serviceId:SwitchPower1" variable="Status" id="21" value="1"/>
<state service="urn:upnp-org:serviceId:HVAC_FanOperatingMode1" variable="Mode" value="Auto" id="22"/>
<state service="urn:micasaverde-com:serviceId:HaDevice1" variable="BatteryDate" id="23" value="1440435018"/>
<state service="urn:micasaverde-com:serviceId:HaDevice1" variable="BatteryLevel" value="100" id="24"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="PollOk" id="25" value="391"/>
<state service="urn:micasaverde-com:serviceId:ZWaveNetwork1" variable="ConsecutivePollFails" id="26" value="0"/>
<state service="urn:micasaverde-com:serviceId:HaDevice1" variable="ChildrenSameRoom" value="1" id="27"/>
<state service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="LastRouteUpdate" id="28" value="1440426059"/>
<state service="urn:micasaverde-com:serviceId:HaDevice1" variable="LastTimeCheck" id="29" value="1440373794"/>
<state service="urn:micasaverde-com:serviceId:HaDevice1" variable="LastTimeOffset" value="-4" id="30"/>
<state service="urn:micasaverde-com:serviceId:HVAC_OperatingState1" variable="ModeState" id="31" value="Idle"/>
<state service="urn:micasaverde-com:serviceId:HVAC_OperatingState1" variable="ModeStateForEnergy" value="1" id="32"/>
<state id="230" service="urn:upnp-org:serviceId:TemperatureSetpoint1" variable="SetpointTarget" value="72"/>
<state id="68" service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="LastNnu" value="1440396000,4"/>
<state id="70" service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="LastArr" value="1440396000,4"/>
<state id="4" service="urn:upnp-org:serviceId:SwitchPower1" variable="Target" value="1"/>
<state id="45" service="urn:upnp-org:serviceId:HVAC_UserOperatingMode1" variable="ModeTarget" value="AutoChangeOver"/>
<state id="50" service="urn:upnp-org:serviceId:TemperatureSetpoint1_Heat" variable="CurrentSetpoint" value="72"/>
<state id="63" service="urn:upnp-org:serviceId:TemperatureSetpoint1_Cool" variable="CurrentSetpoint" value="72"/>
<state id="137" service="urn:micasaverde-com:serviceId:ZWaveDevice1" variable="PollNoReply" value="1"/>
<state id="234" service="urn:micasaverde-com:serviceId:HaDevice1" variable="CommFailure" value="0"/>
<state id="235" service="urn:micasaverde-com:serviceId:HaDevice1" variable="CommFailureTime" value="0"/>
</states>
<ControlURLs>
<service_58 service="urn:upnp-org:serviceId:HVAC_FanOperatingMode1" ControlURL="/upnp/control/dev_58" EventURL="/upnp/event/dev_58" serviceType="urn:schemas-upnp-org:service:HVAC_FanOperatingMode:1"/>
<service_59 service="urn:micasaverde-com:serviceId:HVAC_OperatingState1" ControlURL="/upnp/control/dev_59" EventURL="/upnp/event/dev_59" serviceType="urn:micasaverde-com:serviceId:HVAC_OperatingState:1"/>
<service_60 service="urn:upnp-org:serviceId:HVAC_UserOperatingMode1" ControlURL="/upnp/control/dev_60" EventURL="/upnp/event/dev_60" serviceType="urn:schemas-upnp-org:service:HVAC_UserOperatingMode:1"/>
<service_61 service="urn:upnp-org:serviceId:FanSpeed1" ControlURL="/upnp/control/dev_61" EventURL="/upnp/event/dev_61" serviceType="urn:schemas-upnp-org:service:FanSpeed:1"/>
<service_62 service="urn:upnp-org:serviceId:TemperatureSensor1" ControlURL="/upnp/control/dev_62" EventURL="/upnp/event/dev_62" serviceType="urn:schemas-upnp-org:service:TemperatureSensor:1"/>
<service_63 service="urn:upnp-org:serviceId:TemperatureSetpoint1" ControlURL="/upnp/control/dev_63" EventURL="/upnp/event/dev_63" serviceType="urn:schemas-upnp-org:service:TemperatureSetpoint:1"/>
<service_64 service="urn:upnp-org:serviceId:TemperatureSetpoint1_Heat" ControlURL="/upnp/control/dev_64" EventURL="/upnp/event/dev_64" serviceType="urn:schemas-upnp-org:service:TemperatureSetpoint:1"/>
<service_65 service="urn:upnp-org:serviceId:TemperatureSetpoint1_Cool" ControlURL="/upnp/control/dev_65" EventURL="/upnp/event/dev_65" serviceType="urn:schemas-upnp-org:service:TemperatureSetpoint:1"/>
<service_66 service="urn:upnp-org:serviceId:SwitchPower1" ControlURL="/upnp/control/dev_66" EventURL="/upnp/event/dev_66" serviceType="urn:schemas-upnp-org:service:SwitchPower:1"/>
<service_67 service="urn:micasaverde-com:serviceId:EnergyMetering1" ControlURL="/upnp/control/dev_67" EventURL="/upnp/event/dev_67" serviceType="urn:schemas-micasaverde-com:service:EnergyMetering:1"/>
<service_68 service="urn:micasaverde-com:serviceId:HaDevice1" ControlURL="/upnp/control/dev_68" EventURL="/upnp/event/dev_68" serviceType="urn:schemas-micasaverde-com:service:HaDevice:1"/>
</ControlURLs>
</device>
Right now when I try to change temp I get:
2015-08-24 13:58:51 DEBUG o.o.b.m.i.MiosUnitConnector[:185]- callDevice: Need to remote-invoke Device 'unit:house,device:22/service/urn:upnp-org:serviceId:TemperatureSetpoint1/SetpointTarget' action '72' and current state '72')
2015-08-24 13:58:51 WARN o.o.b.m.i.MiosUnitConnector[:190]- callDevice: Command '72' not supported, or missing command: mapping, for Item 'Basement_Tstat_SetPoint'
2015-08-24 13:58:52 DEBUG o.o.b.m.i.MiosUnitConnector[:699]- processResponse: success! loadTime=1439903586, dataVersion=903590446 devices(0) scenes(0) rooms(0) sections(0)
My item looks like:
Group Tstat10 (Thermostats)
Group Tstat10_Chart (Tstat10)
Number Basement_Tstat_Temperature "Basement Temperature [%.1f °F]" <temperature> (Tstat10_Chart, Temperature) {mios="unit:house,device:22/service/TemperatureSensor1/CurrentTemperature"}
String Basement_Tstat_OpMode "Basement Operating Mode" <settings> (Tstat10) {mios="unit:house,device:22/service/HVAC_UserOperatingMode1/ModeStatus"}
Number Basement_Tstat_BatteryLevel "Basement Battery Level [%d]" <heating> (Tstat_Battery) {mios="unit:house,device:22/service/HaDevice1/BatteryLevel"}
String Basement_Tstat_ModeState "Basement Mode State [%s]" <settings> (Tstat10, HVAC_Mode) {mios="unit:house,device:22/service/HVAC_OperatingState1/ModeState"}
//String Basement_Tstat_SetPoint "Basement Setpoint [%s]" <temperature> (Tstat10) {mios="unit:house,device:22/service/urn:upnp-org:serviceId:TemperatureSetpoint1/CurrentSetpoint"}
String Basement_Tstat_SetPoint "Basement Setpoint [%s]" <temperature> (Tstat10) {mios="unit:house,device:22/service/urn:upnp-org:serviceId:TemperatureSetpoint1/SetpointTarget"}
Number Basement_Tstat_Humidity "Basement Humidity [%d %%]" <humidity> (Tstat10_Chart, Humidity) {mios="unit:house,device:24/service/HumiditySensor1/CurrentLevel"}
Number Basement_Chart_Period "Chart Period"
My sitemap:
Text item=Basement_Tstat_Temperature valuecolor=[>80="red",>72="orange",>69="green",<69="blue",<60="purple"] {
Text item=Basement_Tstat_Temperature valuecolor=[Basement_Tstat_Temperature>80="red",>72="orange",>69="green",<69="blue",<60="purple"] {
Frame {
Switch item=Basement_Chart_Period label="Chart Period" mappings=[0="Day", 1="Week", 2="Month", 3="Year"]
Chart item=Tstat10_Chart period=D refresh=10000 visibility=[Basement_Chart_Period==0, Basement_Chart_Period=="Uninitialized"]
Chart item=Tstat10_Chart period=W refresh=10000 visibility=[Basement_Chart_Period==1]
Chart item=Tstat10_Chart period=M refresh=10000 visibility=[Basement_Chart_Period==2]
Chart item=Tstat10_Chart period=Y refresh=10000 visibility=[Basement_Chart_Period==3]
Text item=Basement_Tstat_Humidity
Setpoint item=Basement_Tstat_SetPoint minValue=40 maxValue=80 step=1
Switch item=Basement_Tstat_OpMode mappings=[HeatOn="Heat", CoolOn="Cool", AutoChangeOver="Auto", Off="Off"]
Text item=Basement_Tstat_ModeState
