How can i get the current time in hh:mm:ss in rule to append on a string item to display in habpanel? The topics I read in this bolg produces all errors.
This al depends on what exactly you are trying to achieve. If you could describe in more detail what you need, people can come up with the most appropriate solution
At last I found the solution:
rule “Pumpenstatus"
Item Pumpe_Status changed
if ( Pumpe_Status.state == ON )
val String currentTime = String::format( “%1$tH:%1$tM”, new java.util.Date )
Pumpe_Label.postUpdate(“Pumpe läuft seit " + currentTime)
executeCommandLine(”/usr/local/bin/openhab2/writelog.sh Pumpe an”)
if ( Pumpe_Status.state == OFF )
Pumpe_Label.postUpdate(“Pumpe ist aus”)
executeCommandLine("/usr/local/bin/openhab2/writelog.sh Pumpe aus")
