I succesfully set up a Scene Switch to control an RGB Light Strip.
However, what I would like to achieve is that if I turn it on it cyles through different preset Scenes
I am using the Scene Switch as follows:
rule "Kitchen Switch"
when Item Zwave_Switch_SceneNumber received update
switch(Zwave_Switch_SceneNumber.state.toString) {
case "1.0": {
Kitchen_LightStrip_Toggle.sendCommand(ON)
case "3.0": {
Kitchen_LightStrip_Toggle.sendCommand(OFF)
The result should be something like:
//Light Setting 1
Kitchen_LightStrip_Color.sendCommand("290,88,9")
Kitchen_LightStrip_Dimmer.sendCommand("50")
//Light Setting 2
Kitchen_LightStrip_Color.sendCommand("230,88,9")
//Light Setting 3
Kitchen_LightStrip_Dimmer.sendCommand("100")
case "1.0": {
if Kitchen_LightStrip_Toggle is OFF send Command ON
Set light to the last light setting it was at
if Kitchen_LightStrip_Toggle is ON and set to Light Settiung 1
Switch from Light Setting 1 to Light Setting 2
if Kitchen_LightStrip_Toggle is ON and set to Light Settiung 2
Switch from Light Setting 2 to Light Setting 3
if Kitchen_LightStrip_Toggle is ON and set to Light Settiung 3
Switch from Light Setting 3 to Light Setting 1
case "3.0": {
How do I accomplish what I am looking for??
Thanks for the help!
MDAR
#2
Hi
I think I’ve got something very similar running happily.
Introduce a virtual item “scenenumber” of Number type and change that on every switch toggle, then change your rule to get triggered on changes to that new item.
Thank you all for your input. This is what I came up with:
var Number kitchenScene = 1
val Number maxKitchenScene = 3
switch(Zwave_Switch_SceneNumber.state) {
case 1.0: {
if(Kitchen_LightStrip_Toggle.state==OFF)
{Kitchen_LightStrip_Toggle.sendCommand(ON)
else {
if (kitchenScene >= maxKitchenScene) {
kitchenScene = 1
Kitchen_LightStrip_SceneNumber.postUpdate(kitchenScene)}
else{
kitchenScene = kitchenScene + 1
case 3.0: {
Kitchen_LightStrip_Toggle.sendCommand(OFF)}
case 2.0: {
Kitchen_SinkLight.sendCommand(ON) }
case 4.0: {
Kitchen_SinkLight.sendCommand(OFF)}
rule "Scene Selector Kitchen Strip"
Item Kitchen_LightStrip_SceneNumber changed
switch (Kitchen_LightStrip_SceneNumber.state) {
case 1: {
logInfo("Kitchen Switch", "Scene 1")
//Some color
case 2: {
logInfo("Kitchen Switch", "Scene2")
//Some color
case 3: {
logInfo("Kitchen Switch", "Scene 3")
//Some color
It is working. I hope that this is the correct way to do it.
