I’m trying to get a Cyrus flood sensor (https://www.notebooksbilliger.de/cyrus+smarthome+flood+sensor+z+wave+plus) to work with OpenHAB, but I do not manage to get it properly included. I assume that it’s not in the database, but I have no clue how to add it as I do not get any kind of ID or any information from it. Please see the following screenshot:
So it seems to me properly discovered and included in the Z-Wave network, but just unknown. However, to add it to the database I assume I need the vendor (Hersteller) and device id (Typ-Kennzeichen) which I do not have.
I have tried to wake up the device several times and also removed and added it again but no luck. Do you have any suggestion?
Even though if it is not in the database you should be able to properly include it.
I would exclude it, reset the device and try to include it again until a node.xml file is created.
It looks like some of the Cyrus devices are from manufacturer Shenzhen, so you may be able to identify it in the database: http://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/458
thanks for your reply. I tried inclusion / reset / inclusion / … a couple of times but unfortunately no luck with it, yet. The max is that it is not called “Node” but “Z-Wave Node” in OpenHAB and as I showed in the screenshot.
I might give it a try in Domoticz to see whether it’s gonna be recognized there and if it is, so to get more information about the device and hopefully get it then successfully included in OpenHAB.
Are you sure it’s really waking up? I don’t see a wakeup time in the attributes that I would have expected (I think). What do the logs show is happening?
it seems to get closer to working. I still have a “?” at the icon but it’s de-facto recognized as flood sensor. I took the hint to look at the database for Shenzhen devices and figured out that pressing the include button 3 times is the magic way to go (the two devices from Cyrus didn’t come with any manual from which I could have seen that).
Still the questionmark seems to tell it’s not yet working and when I click on device reinitialization I get the following error in the log:
17:00:38.726 [ERROR] [est.core.internal.thing.ThingResource] - Exception during HTTP PUT request for update config at 'things/zwave:device:e94667c8:node29/config' for thing 'zwave:device:e94667c8:node29': Thing with UID zwave:device:e94667c8:node29 has no handler attached.
Ok, its online after a few reboots and triple pressing the button, several times. But the trigger doesn’t work.
If its in the water the LED is on, the siren to. But habin says still Untriggered.
