I’d like to record the number of times an item changes state each day. At present I have a item defined as a number, which I reset to zero at midnight each day. Is there a way using some form of persistence that would allow me to record the value of my item at 23:59 each day?
I’d like to avoid having to create separate items for each day of the week, as this is a limited workaround.
Use a second item which is set to the current value of your actual item at 23:59. Persisting this secondary item should be possible with any persistence servicd in stock.
