I’ve been setting up bunch of sensors and every possible thing for the past few days and it’s working great. Except today, tried something as simple as displaying date, but getting a blank like - -. - - . I don’t know if there’s something I am doing wrong or the binding ntp/DateTime is not working. Here’s my item:
DateTime Date “Date [%1$tA, %1$td.%1$tm.%1$tY]” { ntp=“America/New_York:en_EN” }
My sitemap:
Text item=Date
I’ve tried everything from changing server (to 0.us.pool.ntp.org) in openhab.cfg to restarting openhab but still get a blank. This has got me stumped as it seems very basic.
Do I have to create a rule to get the date updated?
If not, maybe I’ll try getting date from other sources.
Appreciate any help.
no clue so far from the logs. I am trying other servers too 1.us.pool.ntp.org, if anyone gives me his/her config then I know it’s a problem with my setup and not the ntp binding. Btw, I am using 1.7.1 version.
Also, I realized I unzipped all the .jars from the addons zip file to the addons folder, maybe one of the other addons is creating a problem? I don’t want to remove anything essential, so stuck with all the possible addons one could have.
Hi, you only want the JARs for the addons you’re using in the addons folder! Remove the JAR files for unused addons, restart openHAB and see if that helps.
It worked, but not sure which one did it. Because, I first changed the server to 1.us.pool.ntp.org, then replaced the NTP jar file with the file I had in my addon folder(although both had similar sizes) and finally deleted all the non-essential jar files (the ones that sound like commercial products) and then restarted raspberry pi. Everything came to life including the date showing up. Thanks watou!
Although, just now the my.openhab.org is down for a while, so not able to see it outside my network. Does this happen often?
Ok, glad it’s not just me then.
Never happened to me in last 2 weeks, so I will let this pass as an one off case.
But it reminds me to make my rules take such things into account when I trigger tasks via ifttt. For example I don’t want my watering schedule to start and then never stop (there goes my carpet).
