i use following term
Number Temperature “Außentemperatur [%.2f °C]” {weather=“locationId=home-OWM, type=temperature, property=current”}
The result ist for example 8.33 C
How can i get the result with a comma 8,33 instead of point?
Did you set your locale in openHAB and on your machine?
How can I Do this?
In openHAB, in the paperUI.
What machine are you using?
raspi
The Regional Settings are Germany
Is the a replace function i can use by displaying
With raspian or openHABian?
openHABian
sudo openhabian-config
the local setting is de_DE.UTF8
Thanks; this was the solution
