[solved] DecimalType error in rule
The rule looks like this:
rule "ruleEMeterPower"
        Item nPVGeneratorPac changed or
        Item nEMeterPPurchase changed
        var Number nPowerPVGenerator = (nPVGeneratorPac.state as DecimalType)
        var Number nPowerEMeterPurchase = (nEMeterPPurchase.state as DecimalType)
        nEMeterPTotal.postUpdate(nPowerPVGenerator + nPowerEMeterPurchase)
When starting openHAB 2 the console gives the following error message:
[ERROR] [.script.engine.ScriptExecutionThread] - Rule ‘ruleEMeterPower’: org.eclipse.smarthome.core.library.types.DecimalType
However the rule seems to execute fine as the item nEMeterPTotal is updated correctly.
Still, I’d like to get rid of this error message.
So what could I do to fix this? Do I need to import something?
Thanks.
Taking that as a clue, I would think that perhaps one of your Items is null at startup.
You could wrap your code in an if() that checks that both item states are not-null before attempting.
Alright, that did the trick!
Thank you very much!
For reference, here’s the complete rule:
        if ((nPVGeneratorPac.state != NULL) && (nEMeterPPurchase.state != NULL)) {
