Hi all,
I just noticed that initialize() and handleUpdate() methods in BaseThingHandler are deprecated.
It would be great if there is suggestion which methods to use instead of these two inside the coding maybe as a comment inside / above the method.
For initialize() there is this warning message inside: “BaseThingHandler.initialize() will be removed soon, ThingStatus can be set manually via updateStatus(ThingStatus.ONLINE)”
Does that mean that for the quick initialize we can use now the constructor instead of this method?
I remember it was suggested to do the fast initialization in initialize() instead of constructor before…
Cheers,
Konstantin
