[SOLVED] Device unknow Z‐Stick Gen5 USB Controller Aeon Labs
I am using Z‐Stick Gen5 USB Controller Aeon Labs but in hadmin the appeaerance is device unknow. How Can I import the xml file downloaded from device list from http://www.cd-jackson.com in my oh2? o How Can I actuality my bd?
I’m not 100% sure I understand, but if you are just adding the controller, then it should not show up as an unknown device. The controller needs to be added manually and will not show up as a device (unknown or known) in the same way as other devices.
Or are you trying to add other devices to the ZStick and these are showing up as unknown?
The controller was added, but the attibutes type /id, ect … are unknow.
I do not know if it’s a problem or it’s not important.
No - this is not important for the controller. The controller doesn’t support the standard functions for retrieving this information.
