OK…I get this error now:
Configuration model 'aufgang.rules' has errors, therefore ignoring it: [3,1]: mismatched input 'val' expecting 'when'
Post the whole rules file
rule "Slowly Dim Up"
val int timeoutSecs = 9 // 9 seconds for 15 minutes
var int dimLevel = 100 // Start from 100
var Timer_Up timer = null // Initialise timer to null
Item GPIO4 changed to ON
if (timer === null) { // If there is no timer
logInfo("TIMER", "Starting dimmer loop")
timer = createTimer(now.plusSeconds(0), [ | //Starts immediately
if (dimLevel == 0) { //If we have reached 0
timer = null // cancel timer
} else {
dimLevel = dimLevel -1 // Decrease dimLevel by 1
val int pwmValue = ((dimLevel * 1024) / 100).intValue // Scale dimLevel from 0-100 to 0-1024
val commandString = "gpio pwm 1 " + pwmValue // Create command String
logInfo("LOOP Command Line: ", commandString)
executeCommandLine(commandString) // Execute command String
timer.reschedule(now.plusSeconds(timeoutSecs)) // reschedule timer like a loop
} else {
hmm Thank you. I’m going to try it.
Do I need to use unique names for the timer in both rules?
Not if they are in different files
I tried it this way and it looks like its working:
If you’re not using VSC editor to highlight syntax errors, you gotta keep an eye on your openhab.log
to see if a rules file you just uploaded contains errors.
Syntax is var class-of-variable name-of-this-variable = whatever
In this case, timer class is actually Timer
as well, case is important.
So that’s two errors, it would be
var Timer Timer_Up = null
or whatever.
Next, this part has become nonsense
We know it’s null, because we just set it that way…
It’s really worth reading and following along with the rule, and asking about things that are unclear if needed. You’re not going to get people posting you complete working error-free rules that do exactly what you want, you’ll need to understand enough to fix and modify them.
Having said all that, here is a suggestion. Assuming you never want to have dim-up and dim-down happening at the same time. Put BOTH your rules into one rules file as follows (and delete the spare file)
// Globals
var Timer dimTimer = null // Initialise timer to null
// shared timer so that only one rule runs at a time
// convenient to control both rules with same setting
var int dimLevel = 0 // don't care what value it is
// global so that it can be accessed inside timer
if (dimTimer === null) { // If there is no timer
logInfo("TIMER", "Starting dimup loop")
dimLevel = 100 // initial value
dimTimer = createTimer(now.plusSeconds(0), [ | //Starts immediately
dimTimer = null // cancel timer
} else {
dimTimer.reschedule(now.plusSeconds(timeoutSecs)) // reschedule timer like a loop
rule "Slowly Dim Down"
Item GPIO4 changed to OFF
logInfo("TIMER", "Starting dim down loop")
dimLevel = 0 // initialise
if (dimLevel == 100) { //If we have reached 100
} else {
dimLevel = dimLevel +1 // Increase dimLevel by 1
You need to check the rule triggers, and see if that is what you want.
