I run openhab 2.2.0-amd64 in a docker container under Ubuntu server 16.04.4 LTS.
I dont know if it is a docker or an binding issue. So I start here
I use an usb interface to get values from my energy meter device.
The usb interface itself works fine without problems.
To access the interface I set up an udev rule (name: “lesekopf_strom”).
The rule seems to work corret. The interface connects to ttyUSB1.
ls -l /dev/lesekopf_strom
lrwxrwxrwx 1 root root 7 Mär 25 00:51 /dev/lesekopf_strom -> ttyUSB1
Now my issue.
If I start Openhab container with the option:
--device=dev/ttyUSB1
I get access to the interface with the serial binding
But if I start the container with:
--device=/dev/lesekopf_strom
I get the following error:
java.io.IOException: Error at SerialConnector.openConnection: serial port not found /dev/lesekopf_strom.
I run the container under root. So it could not be an issue with the right …. or?
