Eddiie
(Eddie Eddie)
January 19, 2016, 7:57pm
1
I have been trying to get OH1.8 working with my RaspberryPi and Razberry.
Zway worked when it was installed from a previous attempt.
ls /dev shows /dev/ttyAMA0
This is the second clean install I’ve attempted using the apt-get method.
Addon installed - sudo apt-get install openhab-addon-binding-zwave
I’ve sudo usermod -a -G dialout openhab ; rebooted
The log at start up is simple… The device does not exist. It does.
2016-01-19 19:44:41.445 [INFO ] [.z.internal.ZWaveActiveBinding] - Update config, port = /dev/ttyAMA0
2016-01-19 19:44:41.487 [INFO ] [.service.AbstractActiveService] - ZWave Refresh Service has been started
2016-01-19 19:44:41.787 [INFO ] [b.z.i.protocol.ZWaveController] - Starting Z-Wave controller
2016-01-19 19:44:41.796 [INFO ] [b.z.i.protocol.ZWaveController] - Z-Wave timeout is set to 5000ms. Soft reset is false.
2016-01-19 19:44:41.803 [INFO ] [b.z.i.protocol.ZWaveController] - Connecting to serial port /dev/ttyAMA0
2016-01-19 19:44:42.213 [ERROR] [b.z.i.protocol.ZWaveController] - Serial Error: Port /dev/ttyAMA0 does not exist
2016-01-19 19:44:46.497 [INFO ] [.service.AbstractActiveService] - ZWave Refresh Service has been shut down
pi@raspberrypi:/etc/openhab $
What am I doing wrong?
chris
(Chris Jackson)
January 19, 2016, 8:21pm
2
This is a very common question - the answer is normally related to the permissions that the user has and whether or not they can access the ports…
Hi everybody,
after 2 days of playing around with my raspberry pi and openhab I received the Zwave USB stick.
Unfortunately I am not able to make that one work. Openhab ist installed, habmin and the iPhone App. So far the dry runs where working. Now to the problem with the stick.
The stick shows up in the lsusb as Device 13
pi@raspberrypi:/opt $ lsusb Bus 001 Device 013: ID 0658:0200 Sigma Designs, Inc. Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet …
Eddiie
(Eddie Eddie)
January 19, 2016, 8:35pm
3
There are suggestions to start openhab as root using start.sh but start.sh does not exist when using the apt-get install method.
Eddiie
(Eddie Eddie)
January 19, 2016, 8:54pm
4
There was another suggestion to edit line 5 of /etc/default/openhab .
The comments in that file say if there is no parameter on line 5, then they system will use root:root
this is not the case, it still runs as openhab
Modifying line 5 to be root:root will not launch openhab
Thanks for the help.
ptmuldoon
(Paul Muldoon)
January 19, 2016, 9:00pm
5
This is the Startup script I use in my Ubuntu Server. I think it should also work for the Raspberry.
Take a look at the DAEMON_ARGS on line 56 and see how it sets the USB port of my zwave device?
#!/bin/sh
### BEGIN INIT INFO
# Provides: openhab
# Required-Start: $remote_fs $syslog
# Required-Stop: $remote_fs $syslog
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: OpenHAB Daemon
# Description: Build your smart home in no time!
### END INIT INFO
ROOT_DIR=/opt/openhab
# set path to eclipse folder. If local folder, use '.'; otherwise, use /path/to/eclipse/
eclipsehome="$ROOT_DIR/server";
# set ports for HTTP(S) server
HTTP_PORT=8080
HTTPS_PORT=8443
# get path to equinox jar inside $eclipsehome folder
cp=$(find $eclipsehome -name "org.eclipse.equinox.launcher_*.jar" | sort | tail -1);
# This next line determines what user the script runs as.
# Root generally not recommended but necessary if you are using the Raspberry Pi GPIO from Python.
#USER=root
DAEMON_USER=root
DAEMON_NAME=openhab
DAEMON=/usr/bin/java
DAEMON_ARGS="-Djna.boot.library.path=/usr/lib/jni -Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0 -Dosgi.clean=true -Declipse.ignoreApp=true -Dosgi.noShutdown=true -Djetty.port=$HTTP_PORT -Djetty.port.ssl=$HTTPS_PORT -Djetty.home=. -Dlogback.configurationFile=configurations/logback.xml -Dfelix.fileinstall.dir=addons -Djava.library.path=lib -Djava.security.auth.login.config=./etc/login.conf -Dorg.quartz.properties=./etc/quartz.properties -Dequinox.ds.block_timeout=240000 -Dequinox.scr.waitTimeOnBlock=60000 -Dfelix.fileinstall.active.level=4 -Djava.awt.headless=true -jar $cp $* -console "
PIDFILE=/var/run/$DAEMON_NAME.pid
. /lib/lsb/init-functions
do_start() {
log_daemon_msg "Starting system $DAEMON_NAME daemon"
start-stop-daemon --start --background --pidfile $PIDFILE --make-pidfile --user $DAEMON_USER --chuid $DAEMON_USER --chdir $ROOT_DIR --exec $DAEMON -- $DAEMON_ARGS
log_end_msg $?
do_stop() {
log_daemon_msg "Stopping system $DAEMON_NAME daemon"
start-stop-daemon --stop --pidfile $PIDFILE --retry 10
log_end_msg $?
case "$1" in
start|stop)
do_${1}
restart|reload|force-reload)
do_stop
do_start
status)
status_of_proc "$DAEMON_NAME" "$DAEMON" && exit 0 || exit $?
echo "Usage: /etc/init.d/$DAEMON_NAME {start|stop|restart|status}"
exit 1
esac
exit 0
Eddiie
(Eddie Eddie)
January 19, 2016, 9:01pm
6
FIXED!!!
ls -l /dev/ttyAMA0 shows
pi@raspberrypi:/etc/default $ sudo ls -l /dev/ttyAMA0
crw–w---- 1 root tty 204, 64 Jan 19 19:38 /dev/ttyAMA0
It says “tty” group, so I modified the command to grant openhab to tty instead of dialout
sudo usermod -a -G tty openhab
Now I am out of diskspace using 4GB SD card and Raspian Jessie Full Desktop.
At least I am past this hurdle!!!
