Same problem Happening again. Not sure what you are looking for in the log, 30 seconds is the max I could fit here. (the sensor is Node 39)
21:20:00.088 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Received msg (36): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=39, callback=0, payload=00 27 09 71 05 00 00 00 FF 07 08 00
21:20:00.085 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Transaction lastTransaction outstanding...
21:20:00.590 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - lastTransaction TID 181040: [ABORTED] requiresResponse=false callback: 186
21:20:00.293 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - processReceiveMessage input 36<>92 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=39, callback=0, payload=00 27 09 71 05 00 00 00 FF 07 08 00
21:20:01.143 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 39: Application Command Request (ALIVE:DONE)
21:20:00.833 [INFO ] [smarthome.event.ItemStateChangedEvent] - current_date changed from 2018-10-16T21:19:00.784-0400 to 2018-10-16T21:20:00.790-0400
21:20:00.795 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - STOP transaction timer
21:20:01.741 [DEBUG] [ing.zwave.internal.protocol.ZWaveNode] - NODE 39: resetResendCount initComplete=true isDead=false
21:20:01.566 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=ApplicationCommandHandler[4], type=Request[0], dest=39, callback=0, payload=00 27 09 71 05 00 00 00 FF 07 08 00
21:20:02.457 [DEBUG] [ing.zwave.internal.protocol.ZWaveNode] - NODE 39: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
21:20:02.273 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Start transaction timer to Tue Oct 16 21:20:05 EDT 2018 - 3438ms
21:20:03.035 [DEBUG] [ing.zwave.internal.protocol.ZWaveNode] - NODE 39: SECURITY not supported
21:20:03.474 [DEBUG] [otocol.commandclass.ZWaveCommandClass] - NODE 39: Received COMMAND_CLASS_ALARM V8 NOTIFICATION_REPORT
21:20:03.992 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start
21:20:03.813 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 7: Polling zwave:device:a396fe1d:node7:switch_binary
21:20:04.371 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Transaction lastTransaction outstanding...
21:20:04.171 [DEBUG] [l.commandclass.ZWaveAlarmCommandClass] - NODE 39: NOTIFICATION report - 0 = 0, event=8, status=255, plen=0
21:20:04.774 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - STOP transaction timer
21:20:04.571 [DEBUG] [.converter.ZWaveBinarySwitchConverter] - NODE 7: Generating poll message for COMMAND_CLASS_SWITCH_BINARY, endpoint 0
21:20:05.215 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Start transaction timer to Tue Oct 16 21:20:05 EDT 2018 - 496ms
21:20:04.973 [DEBUG] [l.commandclass.ZWaveAlarmCommandClass] - NODE 39: Alarm Type = BURGLAR (0)
21:20:05.712 [DEBUG] [nsactionManager$ZWaveTransactionTimer] - XXXXXXXXX Timeout.......... 1 outstanding transactions
21:20:05.672 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 4: Polling...
21:20:05.438 [DEBUG] [ndclass.ZWaveBinarySwitchCommandClass] - NODE 7: Creating new message for application command SWITCH_BINARY_GET
21:20:06.242 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 4: Polling zwave:device:a396fe1d:node4:switch_binary
21:20:06.078 [DEBUG] [nsactionManager$ZWaveTransactionTimer] - NODE 4: TID 181040: Timeout at state ABORTED. 3 retries remaining.
21:20:05.826 [DEBUG] [ave.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmValueEvent
21:20:06.860 [DEBUG] [nsactionManager$ZWaveTransactionTimer] - TID 181040: Transaction is current transaction, so clearing!!!!!
21:20:06.675 [DEBUG] [.converter.ZWaveBinarySwitchConverter] - NODE 4: Generating poll message for COMMAND_CLASS_SWITCH_BINARY, endpoint 0
21:20:06.466 [DEBUG] [CommandClassTransactionPayloadBuilder] - At build COMMAND_CLASS_SWITCH_BINARY
21:20:07.958 [DEBUG] [ndclass.ZWaveBinarySwitchCommandClass] - NODE 4: Creating new message for application command SWITCH_BINARY_GET
21:20:07.706 [DEBUG] [ve.internal.protocol.ZWaveTransaction] - TID 181040: Transaction CANCELLED
21:20:07.292 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 39: Got an event from Z-Wave network: ZWaveAlarmValueEvent
21:20:08.584 [DEBUG] [ave.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
21:20:08.404 [DEBUG] [CommandClassTransactionPayloadBuilder] - At build COMMAND_CLASS_SWITCH_BINARY
21:20:08.153 [DEBUG] [ing.zwave.internal.protocol.ZWaveNode] - NODE 7: Encapsulating message, endpoint 0
21:20:09.264 [DEBUG] [ing.zwave.internal.protocol.ZWaveNode] - NODE 4: Encapsulating message, endpoint 0
21:20:09.003 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
21:20:08.813 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 39: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_ALARM, value = 255
21:20:09.921 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 4: notifyTransactionResponse TID:181040 CANCELLED
21:20:09.674 [DEBUG] [ing.zwave.internal.protocol.ZWaveNode] - NODE 4: SECURITY not supported
21:20:09.463 [DEBUG] [ing.zwave.internal.protocol.ZWaveNode] - NODE 7: SECURITY not supported
21:20:10.732 [DEBUG] [ing.zwave.internal.protocol.ZWaveNode] - NODE 4: Command Class COMMAND_CLASS_SWITCH_BINARY is NOT required to be secured
21:20:10.385 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start
21:20:10.196 [DEBUG] [nternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
21:20:11.552 [DEBUG] [ing.zwave.internal.protocol.ZWaveNode] - NODE 39: listening == false, frequentlyListening == false, awake == false
21:20:10.913 [DEBUG] [ing.zwave.internal.protocol.ZWaveNode] - NODE 7: Command Class COMMAND_CLASS_SWITCH_BINARY is NOT required to be secured
21:20:11.948 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 39: Node not awake!
21:20:11.729 [DEBUG] [nternal.converter.ZWaveAlarmConverter] - Alarm converter NOTIFICATION event is 8, type OnOffType
21:20:12.354 [DEBUG] [ing.zwave.internal.protocol.ZWaveNode] - NODE 39: listening == false, frequentlyListening == false, awake == false
21:20:12.586 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 39: Commands processed 1.
21:20:12.796 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 39: Node not awake!
21:20:12.932 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 39: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@5eee9b.
21:20:13.110 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 37: Node not found - has this node been removed?!?
21:20:13.516 [DEBUG] [ing.zwave.internal.protocol.ZWaveNode] - NODE 39: listening == false, frequentlyListening == false, awake == false
21:20:13.727 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 39: Node not awake!
21:20:13.871 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 37: Node not found - has this node been removed?!?
21:20:14.063 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 37: Node not found - has this node been removed?!?
21:20:14.247 [DEBUG] [ing.zwave.internal.protocol.ZWaveNode] - NODE 7: listening == true, frequentlyListening == false, awake == false
21:20:14.456 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Transaction from sendQueue
21:20:14.601 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - getTransactionToSend 6
21:20:14.787 [DEBUG] [zwave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 07 02 25 02 25 BB 59
21:20:14.986 [DEBUG] [ding.zwave.handler.ZWaveSerialHandler] - NODE 7: Sending REQUEST Message = 01 09 00 13 07 02 25 02 25 BB 59
21:20:15.190 [DEBUG] [ding.zwave.handler.ZWaveSerialHandler] - Message SENT
21:20:15.193 [DEBUG] [ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
21:20:15.321 [DEBUG] [ve.internal.protocol.ZWaveTransaction] - TID 181041: Transaction Start type SendData
21:20:15.455 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - processReceiveMessage input 37<>91 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
21:20:15.623 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 181041: [WAIT_RESPONSE] requiresResponse=false callback: 187
21:20:15.882 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
21:20:16.120 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: expected cmd class: COMMAND_CLASS_SWITCH_BINARY
21:20:16.357 [DEBUG] [ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
21:20:16.609 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: expected cmd: 3
21:20:16.756 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - processReceiveMessage input 38<>90 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
21:20:16.931 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage Transactions outstanding: 1
21:20:17.198 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
21:20:17.382 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - STOP transaction timer
21:20:17.647 [DEBUG] [ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
21:20:17.784 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Start transaction timer to Tue Oct 16 21:20:19 EDT 2018 - 1598ms
21:20:17.940 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - processReceiveMessage input 39<>89 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
21:20:18.130 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage lastTransaction: TID 181041: [WAIT_RESPONSE] requiresResponse=false callback: 187
21:20:18.435 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
21:20:18.681 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - STOP transaction timer
21:20:18.942 [DEBUG] [ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 BB 00 00 03 53
21:20:19.080 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Start transaction timer to Tue Oct 16 21:20:19 EDT 2018 - 302ms
21:20:19.245 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - processReceiveMessage input 40<>88 : Message: class=SendData[19], type=Request[0], dest=0, callback=187, payload=BB 00 00 03
21:20:19.434 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 39: Checking transaction 181041 ApplicationCommandHandler.
21:20:19.709 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=SendData[19], type=Request[0], dest=0, callback=187, payload=BB 00 00 03
21:20:19.889 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 39: Checking transaction : state >> WAIT_RESPONSE
21:20:20.209 [DEBUG] [ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 07 03 25 03 00 D0
21:20:20.372 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 39: Checking transaction : node >> 7
21:20:20.539 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - processReceiveMessage input 41<>87 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=7, callback=0, payload=00 07 03 25 03 00
21:20:20.689 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 39: Checking transaction : class >> 113 == 37.
21:20:21.198 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 39: Checking transaction : commd >> 5 == 3.
21:20:20.993 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=ApplicationCommandHandler[4], type=Request[0], dest=7, callback=0, payload=00 07 03 25 03 00
21:20:21.361 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 39: Ignoring transaction since not waiting for data.
21:20:21.829 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
21:20:22.028 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
21:20:22.191 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 7: Adding to device queue
21:20:22.192 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Received msg (41): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=39, callback=0, payload=00 27 04 30 03 FF 0C
21:20:22.371 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 7: Added to queue - size 8
21:20:22.630 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - lastTransaction TID 181041: [WAIT_RESPONSE] requiresResponse=false callback: 187
21:20:22.910 [DEBUG] [ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 27 0A 71 05 00 00 00 FF 07 00 01 08 43
21:20:22.808 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start
21:20:22.808 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 4: Adding to device queue
21:20:23.218 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - processReceiveMessage input 41<>87 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=39, callback=0, payload=00 27 0A 71 05 00 00 00 FF 07 00 01 08
21:20:23.005 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 39: Application Command Request (ALIVE:DONE)
21:20:23.947 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=ApplicationCommandHandler[4], type=Request[0], dest=39, callback=0, payload=00 27 0A 71 05 00 00 00 FF 07 00 01 08
21:20:23.574 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 4: Transaction already in queue - removing original
21:20:24.470 [DEBUG] [ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0A 00 04 00 27 04 30 03 00 0C ED
21:20:24.129 [DEBUG] [ing.zwave.internal.protocol.ZWaveNode] - NODE 39: resetResendCount initComplete=true isDead=false
21:20:24.863 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - processReceiveMessage input 42<>86 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=39, callback=0, payload=00 27 04 30 03 00 0C
21:20:24.683 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 4: Added to queue - size 8
21:20:25.370 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=ApplicationCommandHandler[4], type=Request[0], dest=39, callback=0, payload=00 27 04 30 03 00 0C
21:20:25.033 [DEBUG] [ing.zwave.internal.protocol.ZWaveNode] - NODE 39: Incoming command class COMMAND_CLASS_SENSOR_BINARY, endpoint 0
21:20:25.961 [DEBUG] [ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0A 00 04 00 27 04 30 03 00 0C ED
21:20:25.591 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start
21:20:25.591 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Transaction lastTransaction outstanding...
21:20:26.366 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - processReceiveMessage input 43<>85 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=39, callback=0, payload=00 27 04 30 03 00 0C
21:20:26.193 [DEBUG] [ing.zwave.internal.protocol.ZWaveNode] - NODE 39: SECURITY not supported
21:20:27.074 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=ApplicationCommandHandler[4], type=Request[0], dest=39, callback=0, payload=00 27 04 30 03 00 0C
21:20:26.764 [DEBUG] [nsactionManager$ZWaveTransactionTimer] - XXXXXXXXX Timeout.......... 1 outstanding transactions
21:20:27.559 [DEBUG] [ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0F 00 04 00 27 09 71 05 00 00 00 FF 07 08 00 5E
21:20:27.220 [DEBUG] [otocol.commandclass.ZWaveCommandClass] - NODE 39: Received COMMAND_CLASS_SENSOR_BINARY V2 SENSOR_BINARY_REPORT
21:20:27.911 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - processReceiveMessage input 44<>84 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=39, callback=0, payload=00 27 09 71 05 00 00 00 FF 07 08 00
21:20:27.717 [DEBUG] [nsactionManager$ZWaveTransactionTimer] - NODE 7: TID 181041: Timeout at state WAIT_RESPONSE. 3 retries remaining.
21:20:28.430 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=ApplicationCommandHandler[4], type=Request[0], dest=39, callback=0, payload=00 27 09 71 05 00 00 00 FF 07 08 00
21:20:28.109 [DEBUG] [ndclass.ZWaveBinarySensorCommandClass] - Processing Sensor Type 12
21:20:28.949 [DEBUG] [ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0F 00 04 00 27 09 71 05 00 00 00 FF 07 08 00 5E
21:20:28.629 [DEBUG] [nsactionManager$ZWaveTransactionTimer] - Aborting Transaction!
21:20:29.341 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - processReceiveMessage input 45<>83 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=39, callback=0, payload=00 27 09 71 05 00 00 00 FF 07 08 00
21:20:29.114 [DEBUG] [ndclass.ZWaveBinarySensorCommandClass] - Sensor Type is MOTION
21:20:29.800 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=ApplicationCommandHandler[4], type=Request[0], dest=39, callback=0, payload=00 27 09 71 05 00 00 00 FF 07 08 00
21:20:29.466 [DEBUG] [ve.internal.protocol.ZWaveTransaction] - TID 181041: Transaction ABORTED
21:20:30.311 [DEBUG] [ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0A 00 04 00 27 04 30 03 FF 0C 12
21:20:29.942 [DEBUG] [ndclass.ZWaveBinarySensorCommandClass] - NODE 39: Sensor Binary report, type=Motion, value=255
21:20:30.709 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - processReceiveMessage input 46<>82 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=39, callback=0, payload=00 27 04 30 03 FF 0C
21:20:30.514 [DEBUG] [zwave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 16 EA
21:20:31.297 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=ApplicationCommandHandler[4], type=Request[0], dest=39, callback=0, payload=00 27 04 30 03 FF 0C
21:20:30.912 [DEBUG] [ave.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveBinarySensorValueEvent
