Have followed instructions for Eclipse IDE installation via www.openhab.org, now running on MacOS.
Have cloned an existing marketplace binding which I need to customize due to binding no longer working after a FW update for the system bridge, and it does not seem as the author has responded to issue. I.e. hope to be able to generate a jar file to implement via PaperUI (although newbie to programming).
Have managed to work the code, although have 2 remaining problems after setup task and clean. Any ideas?
Problem stated: “Type mismatch: cannot convert from AsyncResult to Value”.
Value response = m_RpcManager.call(Jid.of("mrha@busch-jaeger.de/rpc"), "RemoteInterface.setDatapoint",
para0, para1);
logger.debug("Response from RPC RemoteInterface.setDatapoint: " + response.getAsString());
boolean resp = response.getAsBoolean();
Proposed solution in Eclipse: Change type of response to AsyncResult. However, doing so will create a new problem: The method getAsString() is undefined for the type AsyncResult.
