Hi
i have integrated a broadlink sensor with MQTT
the item:
String mqtt_sensor_door "S1-Door Sensor" {mqtt="<[mosquitto:broadlink/mqtt_S1_1/door:state:default]"}
The sitemap
Default item=mqtt_sensor_door
the rule
//#https://community.openhab.org/t/design-pattern-motion-sensor-timer/14954/55
var Timer sensor_door_Timer = null
val int timeoutMinutes = 2
rule "sensor_door OFF by Timer"
Item mqtt_sensor_door changed
val stateAsString = mqtt_sensor_door.state.toString
logInfo("INFO","----" + stateAsString + "---")
if (stateAsString.contains("opened")){
logInfo("INFO","MQTTLOG DOOR OPENED 1" +"--" + stateAsString )
if(sensor_door_Timer === null){
//motion_LastUpdate.postUpdate(new DateTimeType())
sensor_door_Timer = createTimer(now.plusMinutes(1)) [
val stateAsStringafter = mqtt_sensor_door.state.toString
logInfo("INFO","MQTTLOG 2" +"--" + stateAsString+"--" )
if (stateAsStringafter.contains("closed")){
logInfo("INFO","MQTTLOG DOOR CLOSED 3" +"--" + stateAsString+"--" )
sensor_door_Timer=null }
else
logInfo("INFO","MQTTLOG DOOR opened 4" +"--" + stateAsString+"--" )
sensor_door_Timer.reschedule(now.plusMinutes(1))]}
//else{logInfo("INFO","MQTTLOG DOOR closed 5" +"--" + stateAsString+"--" )}
is there not a more simple way ?
