[SOLVED] Energy Calculation for Off & On peak usage
I do apologize in advance as I know there are several topics about this subject but I can’t seem to find an answer to my (fairly) trivial problem I’m having.
I have the below rule defined but am getting an error on multiplication (*) symbol saying it cannot be resolved.
The Energy_Cost is defined as a Thing:number. I have also tried it as a string but get further errors.
val minute = now.getHour() * 60 + now.getMinute()
rule "Energy Cost"
    Item Energy_Watts changed
    var cost = Energy_Watts.state instanceof Number
    var Number OFFrate = 0.0074
    var Number ONrate = 0.0152
    var Number MIDrate = 0.0102
    //Off-Peak from 7AM to 7PM
    if (minute > 1140 || minute < 420) {
        Energy_Cost = cost * OFFrate
    //On-Peak from 11AM to 5PM
    if (minute > 660 || minute < 1020) {
        Energy_Cost = cost * ONrate
    //Other times are MidPeak (7AM to 11AM & 5PM to 7PM)
    else {
        Energy_Cost = cost * MIDrate
I have also tried changing the Energy_Watts.state to as Number and other ways but keep getting the error.
This variable (Energy_Watts) is also defined as a number.
I know it has something to do with trying my variable types but can’t seem to figure out where I’m going wrong.
Anyone have any ideas?
Thank you kindly :slight_smile:
Can you show us what you mean here?
Hi.
Try:
var cost = Energy_Watts.state as DecimalType
var OFFrate = 0.0074
Energy_Cost.state = cost * OFFrate
Energy_Cost is not defined anywhere in the rule. If Energy_Cost is an item use
Energy_Cost.sendCommand(cost * ONrate)
Thank everyone for all the suggestions and replies.
@hafniumzinc
Item is defined as a number, sorry Item not Thing.
@Jostein89 & @Jogobo
I updated the code using both suggestions, switch to as DecimalType but then I was getting error about BigDecimal to NumberItems
So then as @Jogobo suggested, I edited to use sendCommand and it works now, which is why you’re seeing the number populated as 15.152 in the first screenshot.
Problem is now when I try to input this into grafana I get the
“unsupported mean iterator type *query.stringinterruptiterator” error because it sees it as a string type, even though its defined as number.
I know this wasn’t part of the original question, should this be marked a resolved and a new thread started?
Thanks again
This seems to become a grafana problem now. I don’t think this is the right place for grafana questions and qualified answers might be quite unlikely.
