Platform information:
- Hardware: RaspBerri Pi 4 Model B Rev 1.2
- OS: Linux 4.19.75-v7l+
- Java Runtime Environment: ??
- openHAB version: 2.5.1-2
Issue: My zwave ZW132 switch stopped working after performing ‘system upgrade’ action from openhabian-config app. I also have a motion detector that still works but the switch remains dead.
It is ‘Online’ in the Things listing but every time I toggle it, I get the following error:
at org.openhab.binding.zwave.handler.ZWaveThingHandler.handleCommand(ZWaveThingHandler.java:1159) ~[?:?]
at sun.reflect.GeneratedMethodAccessor48.invoke(Unknown Source) ~[?:?]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_222]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_222]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:152) [bundleFile:?]
at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [bundleFile:?]
at com.sun.proxy.$Proxy1356.handleCommand(Unknown Source) [?:?]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:74) [bundleFile:?]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:48) [bundleFile:?]
at sun.reflect.GeneratedMethodAccessor60.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_222]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
- Here’s my items-configuration (which worked fine until the upgrade):
Group Huis
Group Rondom
// per Locatie
Group gGarage (Rondom)
Group gOprit (Rondom)
Group gTuin (Rondom)
// Functioneel
Group gSensors (Rondom)
Group gSchakelaar (Rondom)
Switch Gar_Sch_Licht "Licht Garage" <light> (gGarage, gSchakelaar) {channel="zwave:device:c5a04344:node3:switch_binary1"}
Switch Gar_Sens_Beweging "Beweging?" <motion> (gGarage, gSchakelaar, gSensors) {channel="zwave:device:c5a04344:node2:alarm_motion"}
Switch Gar_Sens_Alarm "Alarm" <shield> (gGarage, gSchakelaar, gSensors) {channel="zwave:device:c5a04344:node2:alarm_tamper"}
Number Gar_Sw_Licht_W "Vermogen [%.0f W]" <energy> (gGarage, gSensors) {channel="zwave:device:c5a04344:node3:meter_watts1"}
Number Gar_Sens_Helderheid "Helderheid" <sun_clouds> (gGarage, gSensors) {channel="zwave:device:c5a04344:node2:sensor_luminance"}
Number Gar_Sens_UV "UV-waarde" <sun_clouds> (gGarage, gSensors) {channel="zwave:device:c5a04344:node2:sensor_ultraviolet"}
Number Gar_Sens_Temp "Temperatuur" <temperature> (gGarage, gSensors) {channel="zwave:device:c5a04344:node2:sensor_temperature"}
Number Gar_Sens_Batt "Batterij" <battery> (gGarage, gSensors) {channel="zwave:device:c5a04344:node2:battery-level"}
Switch Oprit_Sch_Licht "Licht Oprit" <light> (gOprit, gSchakelaar) {channel="zwave:device:c5a04344:node3:switch_binary2"}
Number Oprit_Sch_Licht_W "Vermogen [%.0f W]" <energy> (gOprit, gSensors) {channel="zwave:device:c5a04344:node3:meter_watts2"}
String Date "Datum" <calendar> {channel="ntp:ntp:local:string"}
Any help is appreciated. Thanks already
