milo
(M)
May 2, 2019, 5:38am
#1
Hello all,
I have an easy problem for you all…
My string looks like
180.0
I am trying to split the string at the “.” but there is a error display which I don’t understand
string_weewx_windDir.postUpdate(transform("JS", "compassrose.js", MQTT_number_weewx_windDir.state.toString) + "(" +MQTT_number_weewx_windDir.state.toString.split('.').get(0) + "°)")
error:
Error during the execution of rule '5min': 0
halloween
(Hallo Ween)
May 2, 2019, 5:59am
#2
I would split the rule into some lines and insert a loginfo after every line, so you can see, which thing causes the error.
That´s the way i look for errors in complex rules.
milo
(M)
May 2, 2019, 6:02am
#3
it’s only this line in the rule…and it is exactly at the split position if i rmove the split command it works
rule "5min"
Time cron "0 0/2 * * * ?"
halloween
(Hallo Ween)
May 2, 2019, 6:09am
#4
Maybe you can try the following:
make a val of this command and only insert the val into the rule.
val example = MQTT_number_weewx_windDir.state.toString.split('.').get(0)
string_weewx_windDir.postUpdate(transform("JS", "compassrose.js", MQTT_number_weewx_windDir.state.toString) + "(" + example + "°)")
Also insert a loginfo after the val-declaration, then you can see what you really get.
milo
(M)
May 2, 2019, 6:22am
#5
halloween:
val example = MQTT_number_weewx_windDir.state.toString.split(’.’).get(0) string_weewx_windDir.postUpdate(transform(“JS”, “compassrose.js”, MQTT_number_weewx_windDir.state.toString) + “(” + example + “°)”)
What do you mean with
logInfo("5min is", example)
error:
2019-05-02 08:22:00.036 [ERROR] [ntime.internal.engine.ExecuteRuleJob] - Error during the execution of rule '5min': 0
halloween
(Hallo Ween)
May 2, 2019, 9:05am
#6
Insert another loginfo before the val-declaration with:
loginfo("test", MQTT_number_weewx_windDir)
So you will get not only the state of the item. You will get a long information about the whole item.
I use this code below to get the parts of the phone-numbers from my fritzbox and it works, it´s the same syntax like in your code.
val tel00 = Call_Incoming_No.state.toString.split(',').get(0)
val tel01 = Call_Incoming_No.state.toString.split(',').get(1)
milo
(M)
May 2, 2019, 9:24am
#7
your suggestion leads to
2019-05-02 11:22:00.025 [ERROR] [ntime.internal.engine.ExecuteRuleJob] - Error during the execution of rule '5min': An error occurred during the script execution: Could not invoke method: org.eclipse.smarthome.model.script.actions.LogAction.logInfo(java.lang.String,java.lang.String,java.lang.Object[]) on instance: null
But
logInfo("test", MQTT_number_weewx_windDir.toString())
2019-05-02 11:23:00.275 [INFO ] [.eclipse.smarthome.model.script.test] - MQTT_number_weewx_windDir (Type=NumberItem, State=45.0, Label=Windrichtung, Category=null)
opus
(Jürgen Baginski)
May 2, 2019, 9:33am
#8
The correct syntax for gettiung the state would be.
logInfo("test", MQTT_number_weewx_windDir.state.toString())
However, are you sure that the error is coming from that part? What’s about the “transform…”?
milo
(M)
May 2, 2019, 9:37am
#9
opus:
toString()
the transform is working…if iI put this
string_weewx_windDir.postUpdate(transform("JS", "compassrose.js", MQTT_number_weewx_windDir.state.toString) + "(" +MQTT_number_weewx_windDir.state.toString.substring(0,3) + "°)")
this is correctwith no error
opus
(Jürgen Baginski)
May 2, 2019, 9:42am
#10
However if the state is above 99 the substring would need to be .substring(0,4).
milo
(M)
May 2, 2019, 9:44am
#11
That’s why I tried to use split then it should be always fine
milo
(M)
May 2, 2019, 8:28pm
#12
I found this
https://community.openhab.org/t/solved-split-a-string-into-array-list/50935/6
Nur im the Log IT says
Invalid escape sequence
Solution:
You need to escape the dot if you want to split on a literal dot:
val example = MQTT_number_weewx_windDir.state.toString.split('\\.').get(0)
Otherwise you are splitting on the regex .
, which means “any character”.
Note the double backslash needed to create a single backslash in the regex.
