Found answer to problem after I posted.
Recommend reposting your original error and add the solution in an edit so others can benefit or remove the posting entirely. At a minimum edit the title with “[SOLVED]”
Yes, I really wanted to delete it. I can’t figure out where the button is to delete it though.
There should be three little dots in the icons along the bottom of the original posting. Click on that and you should see a little trash can. Though now that it has replies it may not let you delete it now.
At least edit the subject with “[SOLVED]”. There is a little pencil icon to the right of the title.
