Getting this error:
2018-11-14 15:42:00.242 [vent.ChannelTriggeredEvent] - logreader:reader:83005b35:newErrorEvent triggered 2018-11-14 15:42:00.078 [ERROR] [ntime.internal.engine.ExecuteRuleJob] - Error during the execution of rule 'Mein Wecker': An error occurred during the script execution: Could not invoke method: org.eclipse.xtext.xbase.lib.IntegerExtensions.operator_equals(int,int) on instance: null
On this rule:
rule "Mein Wecker"
Time cron "0 0/1 * * * ?"
switch now.getDayOfWeek{
case 1: Heute = "MO"
case 2: Heute = "DI"
case 3: Heute= "MI"
case 4: Heute= "DO"
case 5: Heute= "FR"
case 6: Heute= "SA"
case 7: Heute= "SO"
if (gPERSON1Wecker.members.filter[s | s.name == "PERSON1_WECKER_"+Heute].head.state == ON) {
sollMinute = (gPERSON1Wecker.members.filter[s | s.name == "PERSON1_WECKER_"+Heute+"_M"].head.state as Number).intValue
sollStunde = (gPERSON1Wecker.members.filter[s | s.name == "PERSON1_WECKER_"+Heute+"_H"].head.state as Number).intValue
RunTime = (gPERSON1Wecker.members.filter[s | s.name == "PERSON1_WECKER_"+Heute+"_RUN"].head.state as Number).intValue
Wecken = true
if (sollMinute == now.getMinuteOfHour && sollStunde == now.getHourOfDay && Wecken==true) {
//WECKER_AKTIV to ON, so you can react to a move sensor downstairs or in the kitchen
// i use this for a squeezeboxspeak "Good morning. it is soandsomuch degrees"
// see rule "react to move"
//remove all references if you don't want/need this
sendCommand(PERSON1_WECKER_AKTIV,ON)
//Do Stuff here, like turn on lights,coffee machine and/or radio
//Lichter
Yeelights_1.sendCommand(ON)
Yeelights_2.sendCommand(ON)
//Alexa TTS
AlexaSZ_start.sendCommand('GoodMorning')
AlexaSZ_start.sendCommand('Weather')
AlexaSZ_start.sendCommand('Traffic')
//Benachrichtigungen
sendBroadcastNotification("Ab geht's aufstehen, heute wird ein schöner Tag! Heute hat es "+ YahooTemperatur.toString + " grad.")
logInfo("Wecker Event wurde ausgelöst", "Die Wecker Aktivitäten werden ausgeführt, Runtime ist " + Runtime + " Minuten lang!")
AlexaSZ_MusicProviderId.sendCommand('SPOTIFY')
//AlexaSZ_PlayMusicCommand.sendCommand('Playlist Techno')
AlexaSZ_Player.sendCommand('PLAY')
AlexaSZ_Volume.sendCommand(50)
timerPERSON1Wecker = createTimer(now.plusMinutes(RunTime)) [|
//turn lights,radio etc. of after defined time for day.
//sanity check turn off wecker_aktiv
gLights.sendCommand(OFF)
AlexaSZ_TTS.sendCommand("Ich hoffe du bist schon aus dem Bett du Schlafmütze")
AlexaSZ_Player.sendCommand('PAUSE')
AlexaSZ_start.sendCommand('FlashBriefing')
sendCommand(PERSON1_WECKER_AKTIV,OFF)
timerPERSON1Wecker = null
I don’t quite understand the error and therefore I can’t detect the exception. Can someone help?
