I am trying to install OH 1.8 on Debian Jessie running on a cubietruck.
I have Java 1.8.0_71 installed. I am following the install instruction from this link:
During the installation I get the following error:
> Reading package lists... Done
> Building dependency tree
> Reading state information... Done
> The following NEW packages will be installed:
> openhab-runtime
> 0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
> Need to get 0 B/36.8 MB of archives.
> After this operation, 41.4 MB of additional disk space will be used.
> Selecting previously unselected package openhab-runtime.
> (Reading database ... 56832 files and directories currently installed.)
> Preparing to unpack .../openhab-runtime_1.8.0_all.deb ...
> Unpacking openhab-runtime (1.8.0) ...
> Processing triggers for systemd (215-17+deb8u3) ...
> Setting up openhab-runtime (1.8.0) ...
> Failed to get D-Bus connection: Unknown error -1
> dpkg: error processing package openhab-runtime (--configure):
> subprocess installed post-installation script returned error exit status 1
> Errors were encountered while processing:
> openhab-runtime
> E: Sub-process /usr/bin/dpkg returned an error code (1)
No Problem. I am running the same build as you (armbian). According to all I’ve read, as of Debain 8, it should boot into systemd, not sure why this one isn’t. In any case it’s an easy fix.
I get ‘systemd’ already, and the ‘apt-get install systemd-sysv’ says it’s already installed - of course…
I run osmc - formerly Raspbmc. It is on jessie base.
I get this error:
‘Setting up openhab-runtime (1.8.1) …
Job for openhab.service failed. See ‘systemctl status openhab.service’ and ‘journalctl -xn’ for details.
dpkg: error processing package openhab-runtime (–configure):
E: Sub-process /usr/bin/dpkg returned an error code (1)’
What did you get when you ran systemctl status openhab.service and journalctl -xn?
Before running journalctl -xn try to run systemctl start openhab.service first.
The journalctl output may give more details as to what is happening.
For troubleshooting you can try and run openhab from the command line rather than as a service, That way you can see any error message that may not appear otherwise.
Also, after trying to start openhab did you take a look at the openhab.log file in /var/log/openhab?
I’m pretty sure OSMC is a stripped down version of the full Jessie, but how much it’s stripped down I’m not sure though.
I get after status openhab.service:
* openhab.service - Starts and stops the openHAB Home Automation Bus
Loaded: loaded (/usr/lib/systemd/system/openhab.service; disabled)
Active: failed (Result: resources)
Docs: http://www.openhab.org
When I try to run start openhab.service:
Failed to start openhab.service: Access denied
With sudo: the error is the same.
After sudo journalctl -xn:
– Logs begin at Thu 2016-02-25 17:53:35 CET, end at Tue 2016-03-01 19:22:57 CET. –
Mar 01 19:22:37 Jarvis sshd[8121]: PAM service(sshd) ignoring max retries; 6 > 3
Mar 01 19:22:41 Jarvis sshd[8127]: reverse mapping checking getaddrinfo for 232.5.47.59.broad.bx.ln.dynamic.163data.com.cn [59.47.
Mar 01 19:22:41 Jarvis sshd[8127]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=59.47.5
Mar 01 19:22:43 Jarvis sshd[8127]: Failed password for root from 59.47.5.232 port 2376 ssh2
Mar 01 19:22:46 Jarvis sshd[8127]: Failed password for root from 59.47.5.232 port 2376 ssh2
Mar 01 19:22:48 Jarvis sshd[8127]: Failed password for root from 59.47.5.232 port 2376 ssh2
Mar 01 19:22:51 Jarvis sshd[8127]: Failed password for root from 59.47.5.232 port 2376 ssh2
Mar 01 19:22:54 Jarvis sshd[8127]: Failed password for root from 59.47.5.232 port 2376 ssh2
Mar 01 19:22:57 Jarvis sudo[8131]: osmc : TTY=pts/0 ; PWD=/home/osmc ; USER=root ; COMMAND=/bin/journalctl -xn
Mar 01 19:22:57 Jarvis sudo[8131]: pam_unix(sudo:session): session opened for user root by osmc(uid=0)
I’ve done the chmod root:root, because it was openhab:openhab.
after it was done, I’ve ran your command after sudo su, and I got:
systemctl start openhab service
Failed to start service.service: Unit service.service failed to load: No such file or directory.
Job for openhab.service failed. See 'systemctl status openhab.service' and 'journalctl -xn' for details.
root@Jarvis:/home/osmc# systemctl start openhab.service
After systemctl status openhab.service:
root@Jarvis:/home/osmc# systemctl -l status openhab.service
Mar 03 19:00:17 Jarvis systemd[1]: Failed to start Starts and stops the openHAB Home Automation Bus.
Mar 07 09:05:47 Jarvis systemd[1]: Failed to load environment files: No such file or directory
Mar 07 09:05:47 Jarvis systemd[1]: openhab.service failed to run 'start-pre' task: No such file or directory
Mar 07 09:05:47 Jarvis systemd[1]: Failed to start Starts and stops the openHAB Home Automation Bus.
Mar 07 09:33:39 Jarvis systemd[1]: Failed to load environment files: No such file or directory
Mar 07 09:33:39 Jarvis systemd[1]: openhab.service failed to run 'start-pre' task: No such file or directory
Mar 07 09:33:39 Jarvis systemd[1]: Failed to start Starts and stops the openHAB Home Automation Bus.
Mar 07 09:36:33 Jarvis systemd[1]: Failed to load environment files: No such file or directory
Mar 07 09:36:33 Jarvis systemd[1]: openhab.service failed to run 'start-pre' task: No such file or directory
Mar 07 09:36:33 Jarvis systemd[1]: Failed to start Starts and stops the openHAB Home Automation Bus.
Mar 07 09:33:27 Jarvis sudo[19914]: pam_unix(sudo:session): session opened for user root by osmc(uid=0)
Mar 07 09:33:27 Jarvis su[19915]: Successful su for root by root
Mar 07 09:33:27 Jarvis su[19915]: + /dev/pts/0 root:root
Mar 07 09:33:27 Jarvis su[19915]: pam_unix(su:session): session opened for user root by osmc(uid=0)
Mar 07 09:33:39 Jarvis systemd[1]: openhab.service failed to run ‘start-pre’ task: No such file or directory
– Subject: Unit openhab.service has failed
– Defined-By: systemd
– Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
– Unit openhab.service has failed.
– The result is failed.
Mar 07 09:36:33 Jarvis systemd[1]: openhab.service failed to run ‘start-pre’ task: No such file or directory
