[SOLVED] Error message "dhcpd.service: control process exited, code=exited status 6"
What do you see when you type ifconfig
Edit: If you don’t see wlan0 then use ifconfig -a
If you see wlan0 listed then check that it’s not blocked with sudo rfkill list If you find it blocked let me know and I’ll post how to unblock.
Sorry I apologize, I did go back to the ethernet installation again. After installing I will just leave the dhcpd problem, like in the link you provided before.
I think maybe the wifi problem is because it is a Model B+? Somewhere was written that with the Model B+ the wifi is deactivated by default.
Can’t comment b/c I don’t use the wifi.:neutral_face: OH runs headless so no need to access the RPI and it’s only one power cord and the Ethernet cable.:wink: No need to worry with wifi traffic or signal strength.
So after reinstallation, the same problem with the dhcpd. The error occurs after I activated the wifi with openhabian-config. When I dont activate wifi, I dont get the error.
Did you ever set the country using raspi-config ?
If not, use the openhabian-config tool to remove the wifi setup then use raspi-config to set the country and then setup wifi (again,:sweat_smile:).
If I reset the wifi over openhabian-config (I leave the SSID and Key empty, but still have to provide a country code) then the raspi-config says that it could not communicate with wpa_supplicant and I cant do any wifi settings.
When first opening an ssh connection it says to set the country via raspi-config before using wifi.
Maybe try removing everything wifi related, clean the cache, reboot, then try setting the country. If that doesn’t work you might have to flash a new image and start over.:roll_eyes:
I just did a new installation again. Same dhcpd error.
Does anybody know if that is maybe something model B+ related?
Stay away from this “systemctl status dhcpcd.service” command.:rofl:
Just make sure that you set the RPI IP address as static/reserved in the router and you shouldn’t have any issues.:wink:
Currently installing OH2 on my SSD.
Big thanks to @H102 the tutorial you’ve provided worked perfectly!
And I get the exact same error.
wlan0 is not blocked either soft or hard.
I never got these problems when installing OH and this isn’t the first install …
The error message aside does your OH run fine otherwise?
Maybe you wifi-ers have found a bug.:hushed:
If you would, post the link used to download the image. I’m working with a few others (not wifi related) that are having issues with openhabian image install.
actually can’t reach the apache server, OH2 daemon seems fine and active but I don’t think that the localhost is running…
Trying to make a HTTP request to the correct network socket:
Kind of weird, the installation was easier back in the days lol
When
sudo reboot
'ing the pi stays shutdownd, is this behaviour normal with a USB connected storage drive?
This is so weird
man, but I can’t sleep like that. I need all green OKs at startup :smiley:
I’m the same way.:rofl:
I’m searching github now, what image version did you use?
The first one listed here, v1.4.1?
yes :slight_smile:
same version here
@VioletAnt see the link below, last post, I think this is what you tried earlier, correct or no.
I will try to do a new install and then go right away with raspi-config. Before I used openhabian-config first.
.:crossed_fingers: that it works.
That’s what I thought you were doing earlier.:neutral_face: but it’s obvious I need to work on my writing skills.:rofl:
I think it was more my fault. I thought it would suffice to just try to undo the openhabian-config settings and then run raspi-config.
The guy in the last post of the link you provided. Did he run raspi-config when the installation failed (so he could set the wifi settings for installation) or after he installed it successfully? Because I am not sure if he meant the first. But I dont know how to do that, because it seems if the installations aborts there is no command prompt.
