[SOLVED] Error message in rule
I’ll calculate the dew point (Taupunkt) with this rule:
Item Wetter_Burgstaedt_Temperature changed or
Item Wetter_Burgstaedt_Luftdruck changed
double temp = Wetter_Burgstaedt_Temperature.state
double feuchte = Wetter_Burgstaedt_Luftdruck.state
    double saettigungsDampfDruck = 6.112 * Math.pow(2.71828, (17.62 * temp)/(243.12 + temp))
    double tatsaechlicherdampfDruck = saettigungsDampfDruck / 100 * feuchte
    double taupunkt = 235 * Math.log(tatsaechlicherdampfDruck/6.11) / (17.1 - Math.log(tatsaechlicherdampfDruck/6.11))
    logInfo("rule1", "Regel Wetter: Temperatur: {}, Feuchte: {}, Taupunkt: {}", temp, feuchte, taupunkt)
    true
but I’ve got his errormessages:
2018-09-10 14:01:04.197 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'wetter.rules'
2018-09-10 14:01:34.308 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'wetter.rules', using it anyway:
This expression is not allowed in this context, since it doesn't cause any side effects.
2018-09-10 14:01:34.375 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'wetter.rules'
Will this rule run with this errors or what is going wrong?
Jens
rule xxx
  val temp = Wetter_Burgstaedt_Temperature.state as Number
  val feuchte = Wetter_Burgstaedt_Luftdruck.state as Number
  val double saettigungsDampfDruck = 6.112 * Math.pow(2.71828, (17.62 * temp)/(243.12 + temp))
  val double tatsaechlicherdampfDruck = saettigungsDampfDruck / 100 * feuchte
  val double taupunkt = 235 * Math.log(tatsaechlicherdampfDruck/6.11) / (17.1 - Math.log(tatsaechlicherdampfDruck/6.11))
Thank you,
now the rule was loaded without errors…
Sincerely
:slight_smile: Jens
Try not to use primitive types in the rules DSL it seems that the parser struggles with it.
Change all your double to Number
rule xxx
  val Number saettigungsDampfDruck = 6.112 * Math.pow(2.71828, (17.62 * temp)/(243.12 + temp))
  val Number tatsaechlicherdampfDruck = saettigungsDampfDruck / 100 * feuchte
  val Number taupunkt = 235 * Math.log(tatsaechlicherdampfDruck/6.11) / (17.1 - Math.log(tatsaechlicherdampfDruck/6.11))
