Sorry, it comes again.
I have chage the thread title to english
I used google translate so if it’s the wrong translation, pleas correct it
Please use code fences
Please excuse my last post, it just did not work and my english is not so good.
Raspi 2
OS Catalina
For radiator thermostat control via timer
keep getting the following error messages in the log:
Error occurs only with timer release, but not with each timer release. Sometimes a switching time is skipped. Not on all days, but sometimes 2-3 times a day.
Rule "Create timer"
Time cron "0 0 0 * *?" or // midnight
System started or // Restart or reload rules
Member changed to WT_SchaltMinute or // switching time changed
Member of EZ_SchaltMinute changed or // switching time changed
Member of BZ_SchaltMinute changed or // switching time changed
Member of WC_SchaltMinute changed or // switching time changed // switching time changed
Item planTimer receives command // timer trigger (create next timer)
if (lock) return; // rule already active?
lock = true
logInfo ("timer", "create timer") // Control locks
// from here on WZ_Timer // delete old WZ_Timer, falls active
if (WZ_Timer! == null) WZ_Timer.cancel
WZ_Item = WZ_SchaltMinute.members.filter [m | (m.status as number)> now.getMinuteOfDay] .sortBy [
(State as Number) .intValue] .head as NumberItem // determine next WZ_Timer
if (WZ_Item! == null) {// still at least one timer today
logInfo ("Timer", "Create Timer WZ for {} ({})", WZ_Item.name, WZ_Item.state)
WZ_Timer = createTimer (now.withTimeAtStartOfDay.plusMinutes ((WZ_Item.state as Number) .intValue), [// Create Timer
logInfo ("timer", "timer triggered: {}", WZ_Item.name)
if (WZ_Auto.state! = ON) {// manual operation falls
logInfo ("timer", "But manual operation, abort!")
planTimer.sendCommand (OFF) // plan next BZ_Timer
Return; // and final
val Number wzsoll = if (WZ_Item.name.contains ("On")) 1 else 11 // Target state after WZ_Timer
logInfo ("timer", "required switching operation tool:")
WZ_ist.postUpdate (wdsoll)
if (WZ_Item.name.contains ("1") || // Should the timer be taken into account?
(WZ_Item.name.contains ("2") && WZ_SW_2.state == ON)) {
logInfo ("Timer", "Switching tool active")
if ((WZ_Thermostat.state as Number)! = wzsoll) // Current status deviating?
WZ_Thermostat.sendCommand (wzsoll)
otherwise
logInfo ("timer", "but status wz already reached")
} else {
logInfo ("Timer", "Switching inactive")
... 4 more Timer
Error:
Error:2019-11-21 20:59:00.018 [INFO ] [eclipse.smarthome.model.script.timer] - Timer WC ausgelöst: WC_Uhr2_Ein
2019-11-21 20:59:00.004 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.Timer 125 2019-11-21T20:59:00.000+01:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ {
logInfo(,,)
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@1418508
val wcsoll
logInfo(,)
.postUpdate()
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@c9d96e
} ] threw an unhandled Exception:
at org.eclipse.smarthome.model.script.engine.ScriptError.(ScriptError.java:65) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:140) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:902) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:865) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:224) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:204) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:768) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:220) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluateArgumentExpressions(XbaseInterpreter.java:1132) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1046) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:992) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:151) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:447) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:228) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:190) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) ~[?:?]
at com.sun.proxy.$Proxy248.apply(Unknown Source) ~[?:?]
at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:48) ~[?:?]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [182:org.openhab.core.scheduler:2.5.0.M4]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [182:org.openhab.core.scheduler:2.5.0.M4]
Can someone help me, please, what the error messages mean?
I’m not sure that does anything in a timer’s code block; there is nowhere to return to,
I’m not sure if I found all misspelled or wrong code parts.
Spaces aren’t always allowed, for example !=
and ! =
are different.
Upper/lower case is important, there’s a difference between Return;
and return;
I’m not aware of a key word otherwise
. Use else
instead.
Rule "Create timer"
Member of WT_SchaltMinute changed or // switching time changed
Item planTimer received command // timer trigger (create next timer)
if(lock) return; // rule already active?
lock = true
logInfo("timer", "create timer") // Control locks
if(WZ_Timer !== null) WZ_Timer.cancel // delete old WZ_Timer, falls active
WZ_Item = WZ_SchaltMinute.members.filter[m |
(m.status as Number) > now.getMinuteOfDay].sortBy[(State as Number).intValue].head as NumberItem // determine next WZ_Timer
if(WZ_Item !== null) { // still at least one timer today
logInfo("Timer", "Create Timer WZ for {} ({})", WZ_Item.name, WZ_Item.state)
WZ_Timer = createTimer(now.withTimeAtStartOfDay.plusMinutes((WZ_Item.state as Number).intValue), [ // Create Timer
logInfo("timer", "timer triggered: {}", WZ_Item.name)
if(WZ_Auto.state != ON) { // manual operation falls
logInfo("timer", "But manual operation, abort!")
planTimer.sendCommand(OFF) // plan next BZ_Timer
return; // and final
val Number wzsoll = if(WZ_Item.name.contains("On")) 1 else 11 // Target state after WZ_Timer
logInfo("timer", "required switching operation tool:")
WZ_ist.postUpdate(wdsoll)
if(WZ_Item.name.contains("1") || // Should the timer be taken into account?
(WZ_Item.name.contains("2") && WZ_SW_2.state == ON)) {
logInfo("Timer", "Switching tool active")
if((WZ_Thermostat.state as Number) != wzsoll) WZ_Thermostat.sendCommand(wzsoll) // Current status deviating?
else logInfo("timer", "but status wz already reached")
} else logInfo("Timer", "Switching inactive")
// ... 4 more Timer
Don’t know if it’s important or right, but I’d never seen a trigger(third one) like
Or this trigger too:
It should be received
yeah peter that looks screwy
maybe was supposed to be
Member WT_SchaltMinute changed
like the rest of them but my German not so good so struggling here
Yepp. Always missing some typos I’m pretty sure there are some more in it…
…or
please excuse me and thank you for your advice.
I wanted to do it very well and have the code run again because of the German descriptions of the translator and this nonsense came out of it.
There was such nonsense as “! =”, “otherwise” or “Member changed to”.
It should be a lesson to me!
This was my code:
rule "Timer anlegen"
Time cron " 0 0 0 * * ?" or // Mitternacht
System started or // Neustart oder Rules neu geladen
Member of WZ_SchaltMinute changed or // Schaltzeit geändert
Member of EZ_SchaltMinute changed or // Schaltzeit geändert
Member of BZ_SchaltMinute changed or // Schaltzeit geändert
Member of WC_SchaltMinute changed or // Schaltzeit geändert // Schaltzeit geändert
Item planTimer received command // Timertrigger (nächsten Timer anlegen)
if(lock) return; // Rule bereits aktiv?
lock = true
logInfo("timer","Timer anlegen") // Rule sperren
// ab hier WZ_Timer // alten WZ_Timer löschen, falls aktiv
WZ_Item = WZ_SchaltMinute.members.filter[m|(m.state as Number) > now.getMinuteOfDay].sortBy[
(state as Number).intValue].head as NumberItem // Nächsten WZ_Timer ermitteln
if(WZ_Item !== null) { // noch mindestens ein Timer heute
logInfo("timer","Timer WZ anlegen fĂĽr {} ({})",WZ_Item.name,WZ_Item.state)
WZ_Timer = createTimer(now.withTimeAtStartOfDay.plusMinutes((WZ_Item.state as Number).intValue),[ // Timer anlegen
logInfo("timer","Timer ausgelöst: {}",WZ_Item.name)
if(WZ_Auto.state != ON) { // falls manueller Betrieb
logInfo("timer","Aber manueller Betrieb, Abbruch!")
planTimer.sendCommand(OFF) // nächsten BZ_Timer planen
return; // und Schluss
val Number wzsoll = if(WZ_Item.name.contains("Ein")) 1 else 11 // Sollzustand nach WZ_Timer
logInfo("timer","geforderter Schaltvorgang WZ : ")
WZ_ist.postUpdate(wzsoll)
if (WZ_Item.name.contains("1") || // Soll der Timer berĂĽcksichtigt werden?
logInfo("timer","Schaltvorgang WZ aktiv")
if((WZ_Thermostat.state as Number) != wzsoll) // Aktueller Status abweichend?
else
logInfo("timer","aber Zustand WZ bereits erreicht")
} else {
logInfo("timer","Schaltvorgang inaktiv")
Unfortunately I can not find the mistakes. I have 4 almost same timers for 4 thermostats.
There are daily errors in the log, but not with every triggering and with some timers more frequently. The error block is then about 60 times in the log. The Rule in question is in the last post. The error block is always the same, only with val wzsoll, val ezsoll, val bzsoll or val wcsoll.
logInfo(<XStringLiteralImpl>,<XStringLiteralImpl>,<XMemberFeatureCallImplCustom>)
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@1c32eec (conditionalExpression: false)
val wzsoll
logInfo(<XStringLiteralImpl>,<XStringLiteralImpl>,<XFeatureCallImplCustom>)
<XFeatureCallImplCustom>.postUpdate(<XFeatureCallImplCustom>)
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@3d6719 (conditionalExpression: false)
<XFeatureCallImplCustom>.sendCommand(<XFeatureCallImplCustom>)
at org.eclipse.smarthome.model.script.engine.ScriptError.<init>(ScriptError.java:65) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:991) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:954) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:235) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:215) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:857) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:231) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluateArgumentExpressions(XbaseInterpreter.java:1221) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1135) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:1081) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:458) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:239) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:201) ~[?:?]
at com.sun.proxy.$Proxy599.apply(Unknown Source) ~[?:?]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [bundleFile:?]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [bundleFile:?]
I think the problem comes from there:
When the timer executes what if WZ_Item
So create a string global variable:
var String WZItemName
In the top of the rule:
WZItemName = WZItem.name.toString
And in the timer:
val Number wzsoll = if(WZItemName.contains("Ein")) 1 else 11 // Sollzustand nach WZ_Timer
if (WZItemName.contains("1") || // Soll der Timer berĂĽcksichtigt werden?
(WZItemName.contains("2") && WZ_SW_2.state == ON)) {
else
} else {
If any of the Items in your Group have non-numeric states at timer run time, this line will error.
I would open it out into step-by-step code that allows you to test for numeric before using it in an expression. (and add logging to see the states)
I am currently testing the changes suggested by vincent, but I will not see that until tomorrow. I’ve used a global variable before, but it’s worth a try.
The suggestion of Rossko57 does not seem to me relevant, because the error appears only after the release and the time in the log is correct:
(DEFAULT.Timer 68 2019-12-03T23: 30: 00.000 + 01: 00:
Quite so! I managed to misread the group filter as part of the timer code. That’s a trap for another day
Are these long running timers? A reminder that if you edit a rules file that has already started timers, the timers continue to run but usually fail at their due time with a null
error, because their context has been destroyed.
That could be the solution. I did not realize that the timers continue to run when the rules change.
I delete the timers at midnight and when triggered, but since I am making many changes to the rule because of the issues, it may be that timers remain open. That would also explain why often 60 error messages are in the log. Is it possible to log the open timers?
Nope. Once you reload a rules file, any timers it may have started before are completely orphaned and inaccessible.
To diagnose if this what is happening requires you to understand what your own system is up to, there are no short cuts.
To avoid the issue - or in this case demonstrate whether or not you still get errors - reboot openHAB after your last rules edit of the day.
I have now changed one of the 4 timers and will start openHAB again. Then tomorrow I should see where the problem lies.
That was the solution.
For months I search the error in my code. It did not matter if it was global or local variables or items used as memory for the timers.
The errors came from orphaned timers while saving the rule.
Thanks to rossko57, I now know that the timers are retained with .
It’s not so nice to do a restart of OH after each rule change, as many battery devices take hours to wake up, but the bugs are gone.
