Please read the “How to ask good question” Topic. I can tell from your next post that you did not read it.
One big chunk of text which is awful to read and analyse.
Let me just show en example of your text but formatted “correct” / “nice”.
EDITED
Thanks to all. I agree with the linux solution but I’cant follow now.
As said I followed all the instructions from the org web for windows installation.
On starting “start.bat” nothing happens.
Found a log on openHab2/userdata/logs that reports:
openHAB2/userdata/logs/openhab.log
2020-02-14 10:42:54.887 [SEVERE] [org.apache.karaf.main.Main] - Could not launch framework
java.lang.RuntimeException: Error occurred while checking the system module.
at org.eclipse.osgi.storage.Storage.checkSystemBundle(Storage.java:311)
at org.eclipse.osgi.storage.Storage.createStorage(Storage.java:87)
at org.eclipse.osgi.internal.framework.EquinoxContainer.(EquinoxContainer.java:68)
at org.eclipse.osgi.launch.Equinox.(Equinox.java:31)
at org.eclipse.osgi.launch.EquinoxFactory.newFramework(EquinoxFactory.java:24)
at org.apache.karaf.main.Main.launch(Main.java:256)
at org.apache.karaf.main.Main.main(Main.java:178)
Caused by: org.osgi.framework.BundleException: Invalid manifest header Export-Package: “org.osgi.dto;version=“1.0”,org.osgi.resource;version=“1.0”,org.osgi.resource.dto;version=“1.0”;uses:=“org.osgi.dto”,org.osgi.framework;version=“1.8”,org.osgi.framework.dto;version=“1.8”;uses:=“org.osgi.dto”,org.osgi.framework.hooks.bundle;version=“1.1”;uses:=“org.osgi.framework”,org.osgi.framework.hooks.resolver;version=“1.0”;uses:=“org.osgi.framework.wiring”,org.osgi.framework.hooks.service;version=“1.1”;uses:=“org.osgi.framework”,org.osgi.framework.hooks.weaving;version=“1.1”;uses:=“org.osgi.framework.wiring”,org.osgi.framework.launch;version=“1.2”;uses:=“org.osgi.framework”,org.osgi.framework.namespace;version=“1.1”;uses:=“org.osgi.resource”,org.osgi.framework.startlevel;version=“1.0”;uses:=“org.osgi.framework”,org.osgi.framework.startlevel.dto;version=“1.0”;uses:=“org.osgi.dto”,org.osgi.framework.wiring;version=“1.2”;uses:=“org.osgi.framework,org.osgi.resource”,org.osgi.framework.wiring.dto;version=“1.2”;uses:=“org.osgi.dto,org.osgi.resource.dto”,org.osgi.service.condpermadmin;version=“1.1.1”;uses:=“org.osgi.framework,org.osgi.service.permissionadmin”,org.osgi.service.packageadmin;version=“1.2”;uses:=“org.osgi.framework”,org.osgi.service.permissionadmin;version=“1.2”,org.osgi.service.resolver;version=“1.0”;uses:=“org.osgi.resource”,org.osgi.service.startlevel;version=“1.1”;uses:=“org.osgi.framework”,org.osgi.service.url;version=“1.0”,org.osgi.util.tracker;version=“1.5.1”;uses:=“org.osgi.framework”,org.apache.karaf.version;version=“4.2.7”,org.apache.karaf.jaas.boot.principal;uses:=javax.security.auth;version=“4.2.7”,org.apache.karaf.jaas.boot;uses:=“javax.security.auth,javax.security.auth.callback,javax.security.auth.login,javax.security.auth.spi,org.osgi.framework”;version=“4.2.7”,org.apache.karaf.info;version=“4.2.7”, org.apache.karaf.branding, sun.misc, org.apache.karaf.jaas.boot;uses:=“javax.security.auth,javax.security.auth.callback,javax.security.auth.login,javax.security.auth.spi,org.osgi.framework”;version=4.2.7, org.apache.karaf.jaas.boot.principal;uses:=javax.security.auth;version=4.2.7, org.apache.karaf.diagnostic.core;uses:=org.osgi.framework;version=4.2.7, org.apache.karaf.diagnostic.core.common;uses:=org.apache.karaf.diagnostic.core;version=4.2.7”
at org.eclipse.osgi.util.ManifestElement.parseHeader(ManifestElement.java:353)
at org.eclipse.osgi.container.builders.OSGiManifestBuilderFactory.createBuilder(OSGiManifestBuilderFactory.java:85)
at org.eclipse.osgi.storage.Storage.getBuilder(Storage.java:632)
at org.eclipse.osgi.storage.Storage.checkSystemBundle(Storage.java:263)
… 6 more
I am now reading the log
EDIT:
Question:
Did you run start.bat let it run for 1 Minute and then canceled and tried again?
Quote from MDAR:
I would suggest your try a fresh reinstall of openHAB since it looks like something got messed up on the first launch.
