[SOLVED] esp8266---mqtt----WS2801/WS2812/neopixel
// Neopixel
#include <Adafruit_NeoPixel.h>
// ESP 8266
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
// MQTT Subscribes
const char* SubscribeTo = "esp/1/out";
const char* SubscribeFrom = "esp/1/in";
// WiFi & MQTT Server
const char* ssid = "YourWlan";
const char* password = "YourPassword";
const char* mqtt_server = "192.168.178.38";
WiFiClient espClient;
PubSubClient pubClient(espClient);
long lastMsg = 0;
char msg[50];
String message("#000000");
String lastMessage("#000000");
// Neopixel Config
#define NeoPIN D3
#define NUM_LEDS 30
int brightness = 150;
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, NeoPIN, NEO_RGB + NEO_KHZ800);
void setup() {
  Serial.begin ( 115200 );
  // NeoPixel start
  Serial.println();
  strip.setBrightness(brightness);
  strip.begin();
  strip.show();
  delay(50);
  // WiFi
  setup_wifi();
  // MQTT
  Serial.print("Connecting to MQTT...");
  // connecting to the mqtt server
  pubClient.setServer(mqtt_server, 1883);
  pubClient.setCallback(callback);
  Serial.println("done!");
void callback(char* topic, byte* payload, unsigned int length) {
  Serial.print("Message arrived [");
  Serial.print(topic);
  Serial.print("] ");
  String color("#");
  for (int i = 0; i < length; i++) {
    Serial.print((char)payload[i]);
    if(i > 0){
      color = color + String((char)payload[i]);
  Serial.println();
  // finding payload
  if((char)payload[0] == '#'){
    // setting color
     setNeoColor(color);
void setup_wifi() {
  delay(10);
  // We start by connecting to a WiFi network
  Serial.println();
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED) {
    delay(100);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  Serial.println(WiFi.localIP());
void loop() {
  if (!pubClient.connected()) {
    delay(100);
    reconnect();
  pubClient.loop();
  long now = millis();
  if (now - lastMsg > 60000 || lastMessage.indexOf(message) < 0 ) {
    lastMsg = now;
    Serial.print("Publish message: ");
    Serial.println(message);
    char msg[7];
    message.toCharArray(msg, message.length());
    Serial.print("Publishing...");
    pubClient.publish(SubscribeTo, msg);
    Serial.println("Done!!!");
    lastMessage = message;
  delay(10);
void setNeoColor(String value){
    Serial.println("Setting Neopixel..." + value);
    message = value;
    int number = (int) strtol( &value[1], NULL, 16);
    int r = number >> 16;
    int g = number >> 8 & 0xFF;
    int b = number & 0xFF;
     Serial.print("RGB: ");
    Serial.print(r, DEC);
    Serial.print(" ");
    Serial.print(g, DEC);
    Serial.print(" ");
    Serial.print(b, DEC);
    Serial.println(" ");
   for(int i=0; i < NUM_LEDS; i++) {
      strip.setPixelColor(i, strip.Color( g, r, b ) );
    strip.show();
    Serial.println("on.");
void reconnect() {
  // Loop until we're reconnected
  while (!pubClient.connected()) {
    // Attempt to connect
    if (pubClient.connect("ESP8266Client")) {
      Serial.println("connected");
      // Once connected, publish an announcement...
      pubClient.publish(SubscribeTo, "Restart");
      // ... and resubscribe
      pubClient.subscribe(SubscribeFrom);
    } else {
      Serial.print("failed, rc=");
      Serial.print(pubClient.state());
      Serial.println(" try again in 5 seconds");
      // Wait 5 seconds before retrying
      delay(5000);
items
Group All
Color RGBLed "NeoPixel Color" (All)
String RGBLedColor (All) {mqtt=">[mosquitto:esp/1/out:command:*:default]"}
sitemap NeoPixel label="NeoPixel"
	Frame label="NeoPixel" {
		Colorpicker item=RGBLed icon="slider"
rules file
import org.openhab.core.library.types.*
rule "Set HSB value of item RGBLed to RGB color value"
	Item RGBLed changed
	val hsbValue = RGBLed.state as HSBType
	val brightness = hsbValue.brightness.intValue
	val redValue = ((((hsbValue.red.intValue * 255) / 100) *brightness) /100).toString
	val greenValue = ((((hsbValue.green.intValue * 255) / 100) *brightness) /100).toString
	val blueValue = ((((hsbValue.blue.intValue * 255) / 100) *brightness) /100).toString
	val color = redValue + "," + greenValue + "," + blueValue
	sendCommand( RGBLedColor, color)
the code works fine with phone app mqtt dashboard—but i cant put it to openhab…i think i m not good with subcribtions–please help----with item configuration and rule
Please post the corresponding lines in event.log and openhab.log.
2018-04-17 10:01:53.735 [ome.event.ItemCommandEvent] - Item ‘RGBLed’ received command OFF
2018-04-17 10:01:53.752 [vent.ItemStateChangedEvent] - RGBLed changed from 67,47,100 to 67,47,0
2018-04-17 10:01:55.453 [ome.event.ItemCommandEvent] - Item ‘RGBLed’ received command 320,38,100
2018-04-17 10:01:55.468 [vent.ItemStateChangedEvent] - RGBLed changed from 67,47,0 to 320,38,100
2018-04-17 10:01:55.893 [ome.event.ItemCommandEvent] - Item ‘RGBLed’ received command 216,65,100
2018-04-17 10:01:55.908 [vent.ItemStateChangedEvent] - RGBLed changed from 320,38,100 to 216,65,100
2018-04-17 10:01:56.196 [ome.event.ItemCommandEvent] - Item ‘RGBLed’ received command 227,86,100
2018-04-17 10:01:56.208 [vent.ItemStateChangedEvent] - RGBLed changed from 216,65,100 to 227,86,100
thanks------do u have a esp8266 code…
i want to build every think from scretch…but there is no good examples
Your esp code is good, so there are good examples…
I didn’t read the end of the esp code, It should be good to go
I think you have problems with your OH code instead.
What do you see on your phone mqtt dashboard when you trigger the OH rule?
Does OH send anything at all?
What do the OH logs show?
You don’t need the import statement at the top of your rule file
Try adding logInfo statement to see what happens if the rule:
	Item RGBLed changed
        logInfo("BRIGHTNESS", brightness.toString)
        logInfo("REDVALUE", redValue.toString)
        logInfo("GREENVALUE", greenValue.toString)
        logInfo("BLUEVALUE", blueValue.toString)
        logInfo("COLOR", color)
	RGBLedColor.sendCommand(color)
on my phone i see this picture…on openhab nothing hapens…the color changes very good on mqtt dashboard app…i think i not send the right topic on the item file
Group All
Color RGBLed “NeoPixel Color” (All)
2018-04-17 20:58:38.250 [INFO ] [rest.core.internal.item.ItemResource] - Received HTTP POST request at ‘items/RGBLed’ for the unknown item ‘RGBLed’.
It looks like you items are not defined
Please do a small modification on your items file and look at the openhab log, what happens?
Group All
Color RGBLed “NeoPixel Color” (All){mqtt=">[mosquitto:esp/1/out:command:*:default]"}
2018-04-18 09:50:26.473 [ome.event.ItemCommandEvent] - Item ‘RGBLedColor’ received command 51,255,117
2018-04-18 09:50:26.480 [vent.ItemStateChangedEvent] - RGBLedColor changed from 15,58,255 to 51,255,117
still not working…i cant send a command to broker i think…i change from esp/1/out to esp/1/in and it same…god help me
When that happens:
What do you see on the MQTT dashboard?
Can you post your mqtt.cfg file, please?
when i change the color on my telephone mqtt dashboard then is see on mqtt fx for example this #F700BA…but on openhab logviever i see nothing
# Define your MQTT broker connections here for use in the MQTT Binding or MQTT
# Persistence bundles. Replace <broker> with an ID you choose.
# URL to the MQTT broker, e.g. tcp://localhost:1883 or ssl://localhost:8883
mqtt:broker.url=tcp://192.168.2.122:1883
# Optional. Client id (max 23 chars) to use when connecting to the broker.
# If not provided a random default is generated.
#<broker>.clientId=<clientId>
# Optional. True or false. If set to true, allows the use of clientId values
# up to 65535 characters long. Defaults to false.
# NOTE: clientId values longer than 23 characters may not be supported by all
# MQTT servers. Check the server documentation.
#<broker>.allowLongerClientIds=false
# Optional. User id to authenticate with the broker.
#<broker>.user=<user>
# Optional. Password to authenticate with the broker.
#<broker>.pwd=<password>
# Optional. Set the quality of service level for sending messages to this broker.
# Possible values are 0 (Deliver at most once),1 (Deliver at least once) or 2
# (Deliver exactly once). Defaults to 0.
#<broker>.qos=<qos>
# Optional. True or false. Defines if the broker should retain the messages sent to
# it. Defaults to false.
#<broker>.retain=<retain>
# Optional. True or false. Defines if messages are published asynchronously or
# synchronously. Defaults to true.
#<broker>.async=<async>
# Optional. Defines the last will and testament that is sent when this client goes offline
# Format: topic:message:qos:retained <br/>
#<broker>.lwt=<last will definition>
This is wrong:
Replace with:
mosquitto.url=tcp://192.168.2.122:1883
And then restart openHAB to make sure the binding is updated
The items are:
So the broker name is mosquitto
Your bindings are set to send data not receive.
If you want to receive data on RGBLed you need to change it to:
Color RGBLed “NeoPixel Color” (All){mqtt="<[mosquitto:esp/1/out:state:default]"}
Group All
Color RGBLed NeoPixel Color(All){mqtt="<[mosquitto:esp/1/out:state:default]"}
2018-04-18 11:47:56.268 [INFO ] [rest.core.internal.item.ItemResource] - Received HTTP POST request at 'items/RGBLed' for the unknown item 'RGBLed'.
This item definiton is incorrect too. I didn’t spot it before.
Color RGBLed (All) {mqtt="<[mosquitto:esp/1/out:state:default]"}
2018-04-18 12:34:34.076 [ome.event.ItemCommandEvent] - Item 'RGBLedColor' received command 107,91,255
2018-04-18 12:34:34.082 [ERROR] [.mqtt.internal.MqttMessageSubscriber] - Error processing MQTT message.
java.lang.IllegalArgumentException: Value must be between 0 and 100
	at org.openhab.core.library.types.PercentType.validateValue(PercentType.java:48) [208:org.openhab.core.compat1x:2.2.0]
	at org.openhab.core.library.types.PercentType.<init>(PercentType.java:43) [208:org.openhab.core.compat1x:2.2.0]
	at org.openhab.core.library.types.HSBType.getBrightness(HSBType.java:105) [208:org.openhab.core.compat1x:2.2.0]
	at org.openhab.core.library.types.HSBType.toString(HSBType.java:132) [208:org.openhab.core.compat1x:2.2.0]
	at org.openhab.core.compat1x.internal.TypeMapper.mapToESHType(TypeMapper.java:125) [208:org.openhab.core.compat1x:2.2.0]
	at org.openhab.core.events.EventPublisherDelegate.postUpdate(EventPublisherDelegate.java:63) [208:org.openhab.core.compat1x:2.2.0]
	at org.openhab.binding.mqtt.internal.MqttMessageSubscriber.processMessage(MqttMessageSubscriber.java:150) [212:org.openhab.binding.mqtt:1.11.0]
	at org.openhab.io.transport.mqtt.internal.MqttBrokerConnection.messageArrived(MqttBrokerConnection.java:556) [213:org.openhab.io.transport.mqtt:1.11.0]
	at org.eclipse.paho.client.mqttv3.internal.CommsCallback.deliverMessage(CommsCallback.java:475) [213:org.openhab.io.transport.mqtt:1.11.0]
	at org.eclipse.paho.client.mqttv3.internal.CommsCallback.handleMessage(CommsCallback.java:379) [213:org.openhab.io.transport.mqtt:1.11.0]
	at org.eclipse.paho.client.mqttv3.internal.CommsCallback.run(CommsCallback.java:183) [213:org.openhab.io.transport.mqtt:1.11.0]
	at java.lang.Thread.run(Thread.java:748) [?:?]```
but i have now a good news…i have logs now from openhab when i change the color with phone mqtt dashboard…
2018-04-18 12:42:55.566 [WARN ] [b.core.events.EventPublisherDelegate] - given new state is NULL, couldn’t post update for ‘RGBLed’
Yes this is because the format sent by your dashboard cannot be parsed into a color
Step by step, we will get there.
First change RGBLed to a String for testing:
String RGBLed (All) {mqtt="<[mosquitto:esp/1/out:state:default]"}
What do you get in your log?
