Color RGBLed (All) {mqtt="<[mosquitto:esp/1/out:state:default]"}
2018-04-18 12:53:41.028 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘Set HSB value of item RGBLed to RGB color value’: The name ‘RGBLedColor’ cannot be resolved to an item or type; line 19, column 2, length 11
Ceyhun,
I need more info, not just the errors
Can you show the whole log from when RGBLed gets the update from your dashboard
We can’t debug without context
2018-04-18 13:17:19.855 [vent.ItemStateChangedEvent] - Date changed from 2018-04-18T13:16:19.827+0300 to 2018-04-18T13:17:19.832+0300
2018-04-18 13:18:03.070 [WARN ] [b.core.events.EventPublisherDelegate] - given new state is NULL, couldn't post update for 'RGBLed'
2018-04-18 13:18:19.864 [vent.ItemStateChangedEvent] - Date changed from 2018-04-18T13:17:19.832+0300 to 2018-04-18T13:18:19.837+0300
2018-04-18 13:19:03.075 [WARN ] [b.core.events.EventPublisherDelegate] - given new state is NULL, couldn't post update for 'RGBLed'
2018-04-18 13:19:19.868 [vent.ItemStateChangedEvent] - Date changed from 2018-04-18T13:18:19.837+0300 to 2018-04-18T13:19:19.842+0300
2018-04-18 13:20:03.077 [WARN ] [b.core.events.EventPublisherDelegate] - given new state is NULL, couldn't post update for 'RGBLed'
2018-04-18 13:20:19.863 [vent.ItemStateChangedEvent] - Date changed from 2018-04-18T13:19:19.842+0300 to 2018-04-18T13:20:19.847+0300
2018-04-18 13:21:03.081 [WARN ] [b.core.events.EventPublisherDelegate] - given new state is NULL, couldn't post update for 'RGBLed'
2018-04-18 13:21:19.878 [vent.ItemStateChangedEvent] - Date changed from 2018-04-18T13:20:19.847+0300 to 2018-04-18T13:21:19.851+0300
2018-04-18 13:22:03.089 [WARN ] [b.core.events.EventPublisherDelegate] - given new state is NULL, couldn't post update for 'RGBLed'
2018-04-18 13:22:19.873 [vent.ItemStateChangedEvent] - Date changed from 2018-04-18T13:21:19.851+0300 to 2018-04-18T13:22:19.856+0300
2018-04-18 13:23:03.092 [WARN ] [b.core.events.EventPublisherDelegate] - given new state is NULL, couldn't post update for 'RGBLed'
2018-04-18 13:23:19.887 [vent.ItemStateChangedEvent] - Date changed from 2018-04-18T13:22:19.856+0300 to 2018-04-18T13:23:19.861+0300
2018-04-18 13:24:03.098 [WARN ] [b.core.events.EventPublisherDelegate] - given new state is NULL, couldn't post update for 'RGBLed'
2018-04-18 13:24:19.888 [vent.ItemStateChangedEvent] - Date changed from 2018-04-18T13:23:19.861+0300 to 2018-04-18T13:24:19.865+0300
2018-04-18 13:25:03.100 [WARN ] [b.core.events.EventPublisherDelegate] - given new state is NULL, couldn't post update for 'RGBLed'
2018-04-18 13:25:19.894 [vent.ItemStateChangedEvent] - Date changed from 2018-04-18T13:24:19.865+0300 to 2018-04-18T13:25:19.870+0300
2018-04-18 13:26:03.109 [WARN ] [b.core.events.EventPublisherDelegate] - given new state is NULL, couldn't post update for 'RGBLed'
2018-04-18 13:26:19.900 [vent.ItemStateChangedEvent] - Date changed from 2018-04-18T13:25:19.870+0300 to 2018-04-18T13:26:19.875+0300
2018-04-18 13:27:03.111 [WARN ] [b.core.events.EventPublisherDelegate] - given new state is NULL, couldn't post update for 'RGBLed'
2018-04-18 13:27:19.897 [vent.ItemStateChangedEvent] - Date changed from 2018-04-18T13:26:19.875+0300 to 2018-04-18T13:27:19.880+0300
2018-04-18 13:28:03.111 [WARN ] [b.core.events.EventPublisherDelegate] - given new state is NULL, couldn't post update for 'RGBLed'
2018-04-18 13:56:59.963 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘Set HSB value of item RGBLed to RGB color value’: The name ‘RGBLedColor’ cannot be resolved to an item or type; line 19, column 2, length 11
Did you change your rule as I said above and now:
I need to know what happens in the rule and the value of the items and variables
It is important that your code is exactly as below
rule "Set HSB value of item RGBLed to RGB color value"
Item RGBLed changed
logInfo("RGBLed", RBGLed.state)
val hsbValue = RGBLed.state as HSBType
logIngo("RGBLed", hsbvalue.toString)
val brightness = hsbValue.brightness.intValue
logInfo("BRIGHTNESS", brightness.toString)
val redValue = ((((hsbValue.red.intValue * 255) / 100) *brightness) /100).toString
logInfo("REDVALUE", redValue.toString)
val greenValue = ((((hsbValue.green.intValue * 255) / 100) *brightness) /100).toString
logInfo("GREENVALUE", greenValue.toString)
val blueValue = ((((hsbValue.blue.intValue * 255) / 100) *brightness) /100).toString
logInfo("BLUEVALUE", blueValue.toString)
val color = redValue + "," + greenValue + "," + blueValue
logInfo("COLOR", color)
RGBLedColor.sendCommand(color)
Does you item file looks exactly like this?
Group All
String RGBLed (All) {mqtt="<[mosquitto:esp/1/out:state:default]"}
String RGBLedColor (All) {mqtt=">[mosquitto:esp/1/out:command:*:default]"}
first time i see this — #F7C42—in openhab log thats good i thing----and thank u very much for your help-----
2018-04-18 14:13:45.941 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'demo.items'
2018-04-18 14:14:11.749 [vent.ItemStateChangedEvent] - RGBLed changed from NULL to #F72C5
2018-04-18 14:14:12.242 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Set HSB value of item RGBLed to RGB color value': The name 'RBGLed' cannot be resolved to an item or type; line 5, column 27, length 6
2018-04-18 14:14:20.402 [vent.ItemStateChangedEvent] - Date changed from 2018-04-18T14:13:20.380+0300 to 2018-04-18T14:14:20.385+0300
2018-04-18 14:14:50.196 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `demo.sitemap` does not match the name `NeoPixel` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2018-04-18 14:14:52.910 [ome.event.ItemCommandEvent] - Item 'RGBLed' received command 243,47,100
2018-04-18 14:14:52.917 [vent.ItemStateChangedEvent] - RGBLed changed from #F72C5 to 243,47,100
2018-04-18 14:14:52.922 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Set HSB value of item RGBLed to RGB color value': The name 'RBGLed' cannot be resolved to an item or type; line 5, column 27, length 6
2018-04-18 14:15:11.737 [vent.ItemStateChangedEvent] - RGBLed changed from 243,47,100 to #F72C5
2018-04-18 14:15:11.744 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Set HSB value of item RGBLed to RGB color value': The name 'RBGLed' cannot be resolved to an item or type; line 5, column 27, length 6
2018-04-18 14:15:20.407 [vent.ItemStateChangedEvent] - Date changed from 2018-04-18T14:14:20.385+0300 to 2018-04-18T14:15:20.389+0300
2018-04-18 14:15:49.171 [vent.ItemStateChangedEvent] - RGBLed changed from #F72C5 to Restart
2018-04-18 14:15:49.181 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Set HSB value of item RGBLed to RGB color value': The name 'RBGLed' cannot be resolved to an item or type; line 5, column 27, length 6
2018-04-18 14:16:04.350 [vent.ItemStateChangedEvent] - RGBLed changed from Restart to #F7C42
2018-04-18 14:16:04.361 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Set HSB value of item RGBLed to RGB color value': The name 'RBGLed' cannot be resolved to an item or type; line 5, column 27, length 6
2018-04-18 14:16:11.592 [ome.event.ItemCommandEvent] - Item 'RGBLed' received command 234,89,100
2018-04-18 14:16:11.602 [vent.ItemStateChangedEvent] - RGBLed changed from #F7C42 to 234,89,100
2018-04-18 14:16:11.612 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Set HSB value of item RGBLed to RGB color value': The name 'RBGLed' cannot be resolved to an item or type; line 5, column 27, length 6
2018-04-18 14:16:20.421 [vent.ItemStateChangedEvent] - Date changed from 2018-04-18T14:15:20.389+0300 to 2018-04-18T14:16:20.394+0300
2018-04-18 14:17:04.357 [vent.ItemStateChangedEvent] - RGBLed changed from 234,89,100 to #F7C42
2018-04-18 14:17:04.366 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Set HSB value of item RGBLed to RGB color value': The name 'RBGLed' cannot be resolved to an item or type; line 5, column 27, length 6
2018-04-18 14:17:20.436 [vent.ItemStateChangedEvent] - Date changed from 2018-04-18T14:16:20.394+0300 to 2018-04-18T14:17:20.399+0300
018-04-18 15:14:10.350 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'demo.rules' is either empty or cannot be parsed correctly!
2018-04-18 15:14:10.943 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'demo.rules'
2018-04-18 15:14:16.627 [vent.ItemStateChangedEvent] - RGBLed changed from Restart to #00000
2018-04-18 15:14:17.092 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Set HSB value of item RGBLed to RGB color value': An error occurred during the script execution: Could not invoke method: org.eclipse.smarthome.model.script.actions.LogAction.logInfo(java.lang.String,java.lang.String,java.lang.Object[]) on instance: null
2018-04-18 15:14:20.962 [vent.ItemStateChangedEvent] - Date changed from 2018-04-18T15:13:20.937+0300 to 2018-04-18T15:14:20.942+0300
2018-04-18 15:14:26.375 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `demo.sitemap` does not match the name `NeoPixel` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2018-04-18 15:14:33.283 [ome.event.ItemCommandEvent] - Item 'RGBLed' received command 218,83,100
2018-04-18 15:14:33.297 [vent.ItemStateChangedEvent] - RGBLed changed from #00000 to 218,83,100
2018-04-18 15:14:33.303 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Set HSB value of item RGBLed to RGB color value': An error occurred during the script execution: Could not invoke method: org.eclipse.smarthome.model.script.actions.LogAction.logInfo(java.lang.String,java.lang.String,java.lang.Object[]) on instance: null
2018-04-18 15:15:16.637 [vent.ItemStateChangedEvent] - RGBLed changed from 218,83,100 to #00000
2018-04-18 15:15:16.649 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Set HSB value of item RGBLed to RGB color value': An error occurred during the script execution: Could not invoke method: org.eclipse.smarthome.model.script.actions.LogAction.logInfo(java.lang.String,java.lang.String,java.lang.Object[]) on instance: null
2018-04-18 15:38:46.354 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'demo.rules'
2018-04-18 15:38:46.376 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'demo.rules' is either empty or cannot be parsed correctly!
2018-04-18 15:38:47.245 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'demo.rules'
2018-04-18 15:39:10.019 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename `demo.sitemap` does not match the name `NeoPixel` of the sitemap - please fix this as you might see unexpected behavior otherwise.
2018-04-18 15:39:13.130 [ome.event.ItemCommandEvent] - Item 'RGBLed' received command 283,60,100
2018-04-18 15:39:13.137 [vent.ItemStateChangedEvent] - RGBLed changed from #F7425 to 283,60,100
2018-04-18 15:39:13.615 [INFO ] [clipse.smarthome.model.script.RGBLed] - 283,60,100
2018-04-18 15:39:13.621 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Set HSB value of item RGBLed to RGB color value': Could not cast 283,60,100 to org.eclipse.smarthome.core.library.types.HSBType; line 6, column 17, length 23
2018-04-18 15:39:17.849 [ome.event.ItemCommandEvent] - Item 'RGBLed' received command 104,93,100
2018-04-18 15:39:17.860 [vent.ItemStateChangedEvent] - RGBLed changed from 283,60,100 to 104,93,100
2018-04-18 15:39:17.872 [INFO ] [clipse.smarthome.model.script.RGBLed] - 104,93,100
2018-04-18 15:39:17.879 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Set HSB value of item RGBLed to RGB color value': Could not cast 104,93,100 to org.eclipse.smarthome.core.library.types.HSBType; line 6, column 17, length 23
2018-04-18 15:39:18.819 [ome.event.ItemCommandEvent] - Item 'RGBLed' received command 73,81,100
2018-04-18 15:39:18.835 [INFO ] [clipse.smarthome.model.script.RGBLed] - 73,81,100
2018-04-18 15:39:18.840 [vent.ItemStateChangedEvent] - RGBLed changed from 104,93,100 to 73,81,100
2018-04-18 15:39:18.850 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Set HSB value of item RGBLed to RGB color value': Could not cast 73,81,100 to org.eclipse.smarthome.core.library.types.HSBType; line 6, column 17, length 23
2018-04-18 15:39:21.066 [vent.ItemStateChangedEvent] - Date changed from 2018-04-18T15:38:21.046+0300 to 2018-04-18T15:39:21.051+0300
2018-04-18 15:40:09.946 [vent.ItemStateChangedEvent] - RGBLed changed from 73,81,100 to #F7425
2018-04-18 15:40:09.960 [INFO ] [clipse.smarthome.model.script.RGBLed] - #F7425
2018-04-18 15:40:09.968 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Set HSB value of item RGBLed to RGB color value': Could not cast #F7425 to org.eclipse.smarthome.core.library.types.HSBType; line 6, column 17, length 23
2018-04-18 15:40:21.077 [vent.ItemStateChangedEvent] - Date changed from 2018-04-18T15:39:21.051+0300 to 2018-04-18T15:40:21.055+0300
018-04-18 15:52:06.081 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Set HSB value of item RGBLed to RGB color value': Could not cast 116,95,100 to org.eclipse.smarthome.core.library.types.HSBType; line 6, column 17, length 32
Group All
Color RGBLed (All)
2018-04-18 18:57:38.143 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘Set HSB value of item RGBLed to RGB color value’: The name ‘logIngo’ cannot be resolved to an item or type; line 7, column 9, length 36
