i have deleted the two files from the fix so the original marketplace error has returned but the two new errors have gone so i can confirm that this is something that happend because of the two .jar files
I followed this solution and I’m no longer receiving the errors in my log, but now I can’t open Eclipse.
!ENTRY org.eclipse.osgi 4 0 2018-09-29 12:22:19.370
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: org/eclipse/core/resources/ResourcesPlugin
at org.eclipse.emf.ecore.plugin.EcorePlugin.getWorkspaceRoot(EcorePlugin.java:1131)
at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterImpl.<clinit>(ExtensibleURIConverterImpl.java:393)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getURIConverter(ResourceSetImpl.java:499)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:369)
at org.eclipse.e4.ui.internal.workbench.ResourceHandler.getResource(ResourceHandler.java:350)
at org.eclipse.e4.ui.internal.workbench.ResourceHandler.loadResource(ResourceHandler.java:326)
at org.eclipse.e4.ui.internal.workbench.ResourceHandler.loadMostRecentModel(ResourceHandler.java:231)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.loadApplicationModel(E4Application.java:435)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:260)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:601)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
at org.eclipse.smarthome.designer.ui.internal.application.Application.start(Application.java:32)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:382)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:236)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.core.resources (67).
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:116)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:531)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:324)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:311)
at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:36)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:382)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:336)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:328)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)
at java.lang.ClassLoader.loadClass(Unknown Source)
... 26 more
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.start() of bundle org.eclipse.core.resources.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:792)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:721)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:936)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:319)
at org.eclipse.osgi.container.Module.doStart(Module.java:571)
at org.eclipse.osgi.container.Module.start(Module.java:439)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:454)
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
... 35 more
Caused by: org.eclipse.core.internal.dtree.ObjectNotFoundException: Tree element '/config/config/transform/readme.txt' not found.
at org.eclipse.core.internal.dtree.AbstractDataTree.handleNotFound(AbstractDataTree.java:257)
at org.eclipse.core.internal.dtree.DeltaDataTree.getData(DeltaDataTree.java:585)
at org.eclipse.core.internal.dtree.DataDeltaNode.asBackwardDelta(DataDeltaNode.java:50)
at org.eclipse.core.internal.dtree.DataDeltaNode.asBackwardDelta(DataDeltaNode.java:47)
at org.eclipse.core.internal.dtree.DeltaDataTree.asBackwardDelta(DeltaDataTree.java:88)
at org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDataTree.java:816)
at org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDataTree.java:815)
at org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDataTree.java:792)
at org.eclipse.core.internal.watson.ElementTree.immutable(ElementTree.java:518)
at org.eclipse.core.internal.resources.SaveManager.restore(SaveManager.java:711)
at org.eclipse.core.internal.resources.SaveManager.startup(SaveManager.java:1532)
at org.eclipse.core.internal.resources.Workspace.startup(Workspace.java:2464)
at org.eclipse.core.internal.resources.Workspace.open(Workspace.java:2219)
at org.eclipse.core.resources.ResourcesPlugin.start(ResourcesPlugin.java:447)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:771)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:764)
how did you unzip the files did you unzip on PC and copy through SMB shares or did you unzip directly on RPI?
i downloaded the zipped file too the location recommended using WGET but could not get them too unzip so i had to unzip them on a windows machine copy the .jar files too the openhab rpi home share and moved them from there this did solve the initial problem but introduced two more
I unzipped on my PC and moved them to a directory I had access to on Samba. I then used putty to get to my Pi and used the mv command to move the files.
It looks like they broke my Eclipse when I did this though.
that’s exactly what i did here too i’m not sure what it broke on my setup i was just getting errors and in the process of trying too fix the errors i broke my setup so had too re flash i’m now trying the same method now
the closest i have come to unzipping the file on rpi is renaming the file from .zip to .ZIP this allowed the unzip utility too open the zip file but just gives a different error
End-of-central-directory signature not found. Either this file is not
a zipfile, or it constitutes one disk of a multi-part archive. In the
latter case the central directory and zipfile comment will be found on
the last disk(s) of this archive.
Solved it after a bit of troubleshooting…maybe it helps someone else…
I forgot to update the JAVA_HOME-variable, so it pointed to an old installation (1.8.0_151). After reinstalling Oracle Java 1.8.0_181 and pointing the variable to the new installation. The error message is gone!
@Kai posted my solution it seems I needed to download a different set of files for openhabian running on a rpi (zulu embedded)
Once downloaded these files unzipped perfectly on my rpi and used sudo mv too move the files too the java home directory listed above a quick restart and all errors gone
Please help the “less experienced” by making a simple “how to” guide to fix this problem, I tried the above mentioned solutions (used and downloaded @Kai’s recommended files from post #14, the commands from post #41, tried to fix permissions per post #44) but it only introduced more errors.
I use openHABian on RPi and Mac OS SSH to copy/paste files to the Rpi
I have been using OH2 about a year now, very happy with it up until the “marketplace-bug”. I mainly use Node Red as my rule engine to link my Daikin AC as a heater (with a Marketplace binding) to my Tado room thermostat and thermostatic radiator valves to make an efficient and user-friendly heating system with a high “WAF”
