I also faced the “Failed downloading Marketplace entries: : Received fatal alert: handshake_failure” error.
I have an Openhabian-Zulu installation.
I downloaded the Java Cryptography Extension from Oracle, extracted the 2 .jar files on my Windows PC and then FTP them to /usr/lib/jvm/zulu-embedded-8-armhf/jre/lib/security on the OH board.
After restarting OH service, the errors are gone.
Ok I feel I need too point this out I thank you all for the thank yous but all I did was follow instructions from other people and compile all there posts into one post
So thanks too all the people who helped me post the complete fix
@martinvw Martin, thanks for pointing out, I activated it in docker. Is it possible this significantly increases CPU usage. The docker CPU indicator (on synology NAS used to be around 5 to 7%) and now went up to +/- 27%
this"solution" compleately messed up my OH. After reboot I can not access openhabianpi:8080 anymore, and if i check the log it seems as there are a few problems with java. Reinstalled, tried again, same failure… so I do NOT reccoment to replace local_policy.jar and US_export_policy.jar in /usr/lib/jvm/zulu-embedded-8-armhf/jre/lib/security/ at openhabian
Same issue here. A ton of errors, paper UI stopped working, grafana, … I tried both the oracle as the Zulu versions with the same result.
Any other possibilities to get the marketplace back?
not really a possibillity to get the market place, but a walkaround good enough for me is the suggestion from @CDriver:
Find your plugin on MarketPlace
Click on the download link - it’ll open a dialog with a URL in it. Copy said URL
Past the URL into a browser and download the jar file.
Copy the jar file into your addons folder in OH setup.
just tried, and worked.
addons folder is accessible via samba: \RASPI-NAME\openHAB-share\openhab2-addons
