I have this error message:
2018-12-22 15:10:22.119 [WARN ] [pse.smarthome.core.items.GenericItem] - failed notifying listener 'avgTemps (Type=GroupItem, BaseType=NumberItem, Members=1, State=15.900390, Label=null, Category=null)' about state update of item avgTemps: null
Reading on the forum I think I understand that it is a Null value that is not correctly interpreted.
I tried to disable every single sensor from the group to understand if one of the values created a problem, but nothing.
Should I debug, but I do not know what bindings, to better understand if there is an error, or is a rule better that eliminates the Null value problem?
this is the sitemap:
Text item = avgTemps
item file:
Group: Number: AVG avgTemps "average temperature [% .1f ° C]" <temperature> (avgTemps)
Number Temperature_day "daytime temperature [% .1f ° C]" <temperature> (avgTemps, TechnicView_Node3) {souliss = "T52: 3: 18"}
Number Temperature_corridor "corridor temperature [% .1f ° C]" <temperature> (avgTemps, TechnicView_Node1) {souliss = "T52: 5: 0"}
Number Temperature_camera "room temperature [% .1f ° C]" <temperature> (avgTemps, TechnicView_Node2) {souliss = "T52: 2: 3"}
Number Temperature_studio "studio temperature [% .1f ° C]" <temperature> (avgTemps, TechnicView_Node12) {souliss = "T52: 12: 9"}
Thanks for your suggestions
