[SOLVED] Feature Request: Squeezebox Binding add "sleep" Channel
You are awesome Mark :+1:
tested on piCorePlayer too - I think you can add this to the docs…
besides that I think I found a bug while testing…
I use Spotify spotty plugin on LMS since a few month and if I now try to list my favorites (channel: playFavorite) only my local favorites show up… none of the spotty favorites - maybe caused by something in their link structure or cover_art related.
I tried adding and removing some links to force a reload of the serverlist but with no luck. If I open my favorites via android app there are all spotty links available in favorites.
edit: I personally don’t use this feature in in that way… so no problem for me - and if you send the corresponding number of the favorite to the itemchannel it will play the spotty links - but you can’t see them in the listing
it seems the problem is not the playFavorite channel but with parsing favoritesList channel from server
2021-02-18 13:29:38.380 [DEBUG] [rnal.handler.SqueezeBoxServerHandler] - Sending command: favorites items 0 100
2021-02-18 13:29:38.410 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'SqueezeServerListFavorite' changed from 5=Zufälxxxxx,6=Zufälxxxxx,24=Die Äxxxxx,25=DAN Dxxxxx,28=Leastxxxxx,29=Luzidxxxxx to 5=Zufälxxxxx,6=Zufälxxxxx,24=Die Äxxxxx,25=DAN Dxxxxx,28=Luzidxxxxx,29=Leastxxxxx
I get this in log if I make changes to the list - the numbers with spotty playlists are missing. My logging is set to debug…
By any chance are the Spotify favorites in a subfolder? The binding currently doesn’t look in subfolders.
If they’re not in subfolders, and you’re comfortable in the Unix/Linux shell, try this.
telnet lms-ip-address 9090
Then type
favorites items 0 200
Send me a PM with the result. It should be a list of all the favorites.
Hi Mark… I edited my previous post - none of the favourites are in subfolders
I try your suggestion and pm you the results
FTR, I also submitted a fix for this issue.
Awesome, Mark! - I’ll test it - thanks again for your effort.
It’s lookin’ good - All Playlists show up now - great job!
