I’ve set up a Pine64 (arm64) with a fresh Fedora 27 (minimal) and installed all updates.
Additionally I’ve installed java-1.8.0-openjdk, the OpenHAB RPM repository and the openhab2 package.
Finally I’ve started and enabled openhab2. 30 minutes later I’m still not able to get anything served on IPv4 port 8080
(browser says ERR_ADDRESS_UNREACHABLE when using http://<device-IPv4>:8080
I am able to connect via SSH, so I am sure that networking works. netstat -tulpn
does not show any IPv4 TCP server besides my SSH daemon. To make things even more strange, netstat shows that OpenHAB is serving on the tcp6 port 8080. I’ve come to the point, where I’d like to ask for some ideas to debug the issue.
FWIW, typing http://[<device-IPv6]:8080
in the browser does not solve the problem either.
Find some more infos in the following.
Any ideas?
[root@openhab ~]# java -version
openjdk version "1.8.0_161"
OpenJDK Runtime Environment (build 1.8.0_161-b14)
OpenJDK 64-Bit Server VM (build 25.161-b14, mixed mode)
[root@openhab ~]# cat /var/log/openhab2/openhab.log
2018-02-03 15:40:19.311 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://192.168.188.54:8080
2018-02-03 15:40:19.356 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://192.168.188.54:8443
2018-02-03 15:40:33.247 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
[root@openhab ~]# systemctl status openhab2
● openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled; vendor preset: disabled)
Active: active (running) since Sat 2018-02-03 15:38:19 CET; 31min ago
Docs: http://docs.openhab.org
https://community.openhab.org
Main PID: 1009 (java)
Tasks: 97 (limit: 4915)
CGroup: /system.slice/openhab2.service
└─1009 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtime -Dopenhab.userdata=/var/lib/openhab2 -Dopenhab.logdir=/var/log/openhab2 -Dfelix.cm.dir=/var/lib/openhab2/config -Djetty.host=0.0.0.0 -Djetty.http.compliance=RFC2616 -Dorg.ops4j.pax.web.listening.addresses=0.0.0.0 -Dorg.osgi.service.http.port=8080 -Dorg.osgi.service.http.port.secure=8443 -Djava.awt.headless=true -Djava.endorsed.dirs=/usr/lib/jvm/java-1.8.0-openjdk-1.8.0.161-0.b14.fc27.aarch64/jre/jre/lib/endorsed:/usr/lib/jvm/java-1.8.0-openjdk-1.8.0.161-0.b14.fc27.aarch64/jre/lib/endorsed:/usr/share/openhab2/runtime/lib/endorsed -Djava.ext.dirs=/usr/lib/jvm/java-1.8.0-openjdk-1.8.0.161-0.b14.fc27.aarch64/jre/jre/lib/ext:/usr/lib/jvm/java-1.8.0-openjdk-1.8.0.161-0.b14.fc27.aarch64/jre/lib/ext:/usr/share/openhab2/runtime/lib/ext -Dkaraf.instances=/var/lib/openhab2/tmp/instances -Dkaraf.home=/usr/share/openhab2/runtime -Dkaraf.base=/var/lib/openhab2 -Dkaraf.data=/var/lib/openhab2 -Dkaraf.etc=/var/lib/openhab2/etc -Dkaraf.logs=/var/log/openhab2 -Dkaraf.restart.jvm.supported=true -Djava.io.tmpdir=/var/lib/openhab2/tmp -Djava.util.logging.config.file=/var/lib/openhab2/etc/java.util.logging.properties -Dkaraf.startLocalConsole=false -Dkaraf.startRemoteShell=true -classpath /usr/share/openhab2/runtime/lib/boot/org.apache.karaf.diagnostic.boot-4.1.3.jar:/usr/share/openhab2/runtime/lib/boot/org.apache.karaf.jaas.boot-4.1.3.jar:/usr/share/openhab2/runtime/lib/boot/org.apache.karaf.main-4.1.3.jar:/usr/share/openhab2/runtime/lib/boot/org.osgi.core-6.0.0.jar org.apache.karaf.main.Main
Feb 03 15:38:19 openhab systemd[1]: Started openHAB 2 - empowering the smart home.
[root@openhab ~]# netstat -tulpn
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 650/sshd
tcp6 0 0 127.0.0.1:8101 :::* LISTEN 1009/java
tcp6 0 0 :::5007 :::* LISTEN 1009/java
tcp6 0 0 :::8080 :::* LISTEN 1009/java
tcp6 0 0 :::22 :::* LISTEN 650/sshd
tcp6 0 0 :::8443 :::* LISTEN 1009/java
tcp6 0 0 127.0.0.1:41759 :::* LISTEN 1009/java
udp 0 0 0.0.0.0:68 0.0.0.0:* 795/dhclient
udp 0 0 127.0.0.1:323 0.0.0.0:* 591/chronyd
udp6 0 0 :::1900 :::* 1009/java
udp6 0 0 :::5353 :::* 1009/java
udp6 0 0 ::1:323 :::* 591/chronyd
udp6 0 0 192.168.188.54:58846 :::* 1009/java
