[SOLVED] findFirst[ ] from Group doesn't find a match
It’s all a big jumble which is rossko57’s point I think.
At each step through the comparisons of the members with the Group the Group’s state gets updated. So the Rule could be triggered before the actual min is arrived at.
I added a 1-sec Thread::sleep() by now. Hope that circumvents said issues. Following your suggestion I do an additional NULL and UNDEF check now. Seems to work fine so far.
You could go a much shorter delay. When triggering from member of, you know that a group recalculation/update is in progress or imminent. But it will only take a few milliseconds.
Waiting longer doesn’t reduce the chances of nothing else happening - it’s just tying up resource.
I know and I quite understand the urge for optimization, but frankly I don’t care about that second :wink: . The rule won’t be triggered that often, anyway.
Is not about optimization. Long running rules can be dangerous. Sleeps longer than 300 msec are risky. You can run the risk of delays in all your rules or all your rules just stopping running in extreme circumstances. See (OH 1.x and OH 2.x Rules DSL only] Why have my Rules stopped running? Why Thread::sleep is a bad idea.
Thanks for the heads-up. Since I’m triggering my rule using ‘Member of gSpritpreise changed’ and all five members of the group might get updated (more or less) simultaneously no further rules can run for at least a full second with my Thread::sleep(1000), if I understood the following correct?
I just changed to a createTimer solution, as suggested in your linked post. Which I use anyway in all other rules.
Correct.
