I think this might actually be a bug report, as I’ve done so very little beyond install a stock image on stock system.
I thought I’d give OH3 a trial as it’s been stable for a while now. I have an rPi4 4GB and I imaged a brand new 32GB SanDisk “Max Endurance” uSD card with the 32-bit release of openHABian v1.6.4
as per the documentation (sha256sum of the uncompressed image is 4d639aebe7061917e7ccb5ecbbe4f95ddfd53778e01d806effbf3a237c3df4df). I booted the board up, and left it alone while I ate dinner.
Watching the webpage during post-boot auto-setup shows a few errors, which I’ve highlighted below (this is a result of $(grep -C2 FAILED first-boot.txt)):
2021-01-11_13:09:24_GMT [openHABian] Waiting for dpkg/apt to get ready... OK
2021-05-05_21:10:03_BST [openHABian] Updating repositories and upgrading installed packages... OK
2021-05-05_21:10:03_BST [openHABian] Installing git package... FAILED
2021-05-05_21:10:03_BST [openHABian] Updating myself from https://github.com/openhab/openhabian, main branch... OK
2021-05-05_21:10:03_BST [openHABian] Starting execution of 'openhabian-config unattended'... OK
2021-05-05_22:12:52_CEST [openHABian] tailscale VPN installation... SKIPPED (no preauthkey defined)
2021-05-05_22:12:52_CEST [openHABian] Applying miscellaneous system settings... realpath: '': No such file or directory
FAILED (setcap java)
2021-05-05_22:12:52_CEST [openHABian] Downloading FireMotD... OK
2021-05-05_22:13:53_CEST [openHABian] Installing Java Zulu CEK to enable unlimited cipher strength... OK
2021-05-05_22:13:53_CEST [openHABian] Beginning install of latest openHAB3 release (stable)... OK
2021-05-05_22:13:54_CEST [openHABian] Adding required keys to apt... FAILED
2021-05-05_22:13:54_CEST [openHABian] Adding openHAB syntax to vim editor... OK
2021-05-05_22:13:55_CEST [openHABian] Adding openHAB syntax to nano editor... OK
2021-05-05_22:14:34_CEST [openHABian] Setting up Samba network shares... OK
2021-05-05_22:14:35_CEST [openHABian] Setting up Samba service... OK
2021-05-05_22:14:36_CEST [openHABian] Applying file permissions recommendations... FAILED (please execute after openHAB is installed)
2021-05-05_22:14:36_CEST [openHABian] Installing Frontail prerequsites (NodeJS)... FAILED
The failure to set permissions is, I believe, probably the important one. After the rPi rebooted, I tried accessing http://IP:8080 but it wasn’t working (connection refused, TCP port 8080 closed).
Believing this was a permissions-related problem, I logged in via ssh, ran openhabian-config, selected OpenHAB3-stable and then forced a re-install of OpenHAB. After that, OpenHAB3 still wasn’t accessible via port 8080, so I ran openhabian-config’s “Apply Improvements/Fix Permissions” and that seemed to sort it.
Am I right in thinking this should’ve worked “out of the box”?
Edit: Here’s the status of trying to start the openhab.service from an earlier attempt, which I believe also points to a permissions issue:
-- A stop job for unit openhab.service has finished.
-- The job identifier is 12086 and the job result is done.
May 05 21:30:13 openhabian systemd[1]: Started openHAB instance, reachable at http://openhabian:8080.
-- Subject: A start job for unit openhab.service has finished successfully
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- A start job for unit openhab.service has finished successfully.
-- The job identifier is 12086.
May 05 21:30:15 openhabian karaf[24686]: !SESSION 2021-05-05 21:30:15.726 -----------------------------------------------
May 05 21:30:15 openhabian karaf[24686]: eclipse.buildId=unknown
May 05 21:30:15 openhabian karaf[24686]: java.version=11.0.11
May 05 21:30:15 openhabian karaf[24686]: java.vendor=Azul Systems, Inc.
May 05 21:30:15 openhabian karaf[24686]: BootLoader constants: OS=linux, ARCH=aarch64, WS=gtk, NL=en_GB
May 05 21:30:15 openhabian karaf[24686]: !ENTRY org.eclipse.osgi 4 0 2021-05-05 21:30:15.809
May 05 21:30:15 openhabian karaf[24686]: !MESSAGE Error reading configuration: Unable to create lock manager.
May 05 21:30:15 openhabian karaf[24686]: !STACK 0
May 05 21:30:15 openhabian karaf[24686]: java.io.IOException: Unable to create lock manager.
May 05 21:30:15 openhabian karaf[24686]: at org.eclipse.osgi.storagemanager.StorageManager.open(StorageManager.java:698)
May 05 21:30:15 openhabian karaf[24686]: at org.eclipse.osgi.storage.Storage.getChildStorageManager(Storage.java:1776)
May 05 21:30:15 openhabian karaf[24686]: at org.eclipse.osgi.storage.Storage.getInfoInputStream(Storage.java:1793)
May 05 21:30:15 openhabian karaf[24686]: at org.eclipse.osgi.storage.Storage.<init>(Storage.java:132)
May 05 21:30:15 openhabian karaf[24686]: at org.eclipse.osgi.storage.Storage.createStorage(Storage.java:85)
May 05 21:30:15 openhabian karaf[24686]: at org.eclipse.osgi.internal.framework.EquinoxContainer.<init>(EquinoxContainer.java:68)
May 05 21:30:15 openhabian karaf[24686]: at org.eclipse.osgi.launch.Equinox.<init>(Equinox.java:31)
May 05 21:30:15 openhabian karaf[24686]: at org.eclipse.osgi.launch.EquinoxFactory.newFramework(EquinoxFactory.java:24)
May 05 21:30:15 openhabian karaf[24686]: at org.apache.karaf.main.Main.launch(Main.java:256)
May 05 21:30:15 openhabian karaf[24686]: at org.apache.karaf.main.Main.main(Main.java:178)
May 05 21:30:15 openhabian systemd[1]: openhab.service: Main process exited, code=exited, status=255/EXCEPTION
