[SOLVED] fritzboxtr0641: Host name may not be null exception
  • Platform information:
    • Hardware: Intel Core I3-4150, 4 GiB RAM, 11 GiB free storage
    • OS: Windows 10 1803
    • Java Runtime Environment: jdk8 8.0.201
    • openHAB version: 2.4.0
  • Issue of the topic:
    Starting the fritzboxtr0641 binding it only outputs an exception and doesn’t run as expected
    • Items configuration related to the issue
      String fboxVersion "FBox Version [%s]" {fritzboxtr064="softwareVersion"}
    • Services configuration related to the issue
      url=https://10.20.30.40.:49443
  • If logs where generated please post these here using code fences:
[ERROR] [org.openhab.binding.fritzboxtr064    ] - bundle org.openhab.binding.fritzboxtr064:1.13.0 (208)[org.openhab.binding.fritzboxtr064.binding(22)] : The activate method has thrown an exception
java.lang.IllegalArgumentException: Host name may not be null
[WARN ] [org.openhab.binding.fritzboxtr064    ] - FrameworkEvent WARNING - org.openhab.binding.fritzboxtr064
org.osgi.framework.ServiceException: org.apache.felix.scr.impl.manager.SingleComponentManager.getService() returned a null service object
I wondered why he tells me, that the hostname is null - I specified the url.
Solution: Remove the (accidentally copied) point after IP address, then it works.
