I´m running openhabian 3.3.0 release, (just upgradede from 3.1).
I cant seem to get the fronius binding to work. I have the bridge up running, but my inverter (Symo Gen 24) and my Smartmeter does not work. When I add them I get “Invalid JSON data receiver”
the deviceID does not seem to be optional…
If it’s the first unit, deviceID = 1
see if you can get the data from the inverter using
192.168.5.7/solar_api/v1/GetInverterRealtimeData.cgi?Scope=Device&DeviceId=1&DataCollection=3PInverterDatabut change the IP address to what it needs to be for you
if you dont specify a device ID the result is:
“Reason”: “CGI-Args: Invalid parameter ‘’ for attribute ‘DeviceId’ (must be numeric)”,
@RZomerman I tried the above, but I get no usefull result…
PS C:\WINDOWS\system32> 10.4.28.169/solar_api/v1/GetInverterRealtimeData.cgi?
At line:1 char:13
- 10.4.28.169/solar_api/v1/GetInverterRealtimeData.cgi?
You must provide a value expression following the ‘/’ operator.
At line:1 char:13
Unexpected token ‘solar_api/v1/GetInverterRealtimeData.cgi?’ in expression or statement.
+ CategoryInfo : ParserError: ([], ParentContainsErrorRecordException
+ FullyQualifiedErrorId : ExpectedValueExpression
The is the debug output.
2022-11-06 18:03:31.806 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'fronius:powerinverter:af42566023:803841959c' changed from UNINITIALIZED (DISABLED) to INITIALIZING
2022-11-06 18:03:31.815 [DEBUG] [rnal.handler.FroniusBaseThingHandler] - Initializing Fronius Symo Inverter Service
2022-11-06 18:03:31.820 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'fronius:powerinverter:af42566023:803841959c' changed from INITIALIZING to UNKNOWN
2022-11-06 18:03:32.906 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'MySmartPlug1Power' changed from 12.881369 to 13.061994
2022-11-06 18:03:32.909 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'MySmartPlug1Voltage' changed from 242.599674 to 242.685329
2022-11-06 18:03:32.871 [DEBUG] [rnal.handler.FroniusBaseThingHandler] - Received Invalid JSON Data
com.google.gson.JsonSyntaxException: java.lang.IllegalStateException: Expected BEGIN_OBJECT but was STRING at line 1 column 1 path $
at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$Adapter.read(ReflectiveTypeAdapterFactory.java:226) ~[?:?]
at com.google.gson.Gson.fromJson(Gson.java:963) ~[?:?]
at com.google.gson.Gson.fromJson(Gson.java:928) ~[?:?]
at com.google.gson.Gson.fromJson(Gson.java:877) ~[?:?]
at com.google.gson.Gson.fromJson(Gson.java:848) ~[?:?]
at org.openhab.binding.fronius.internal.handler.FroniusBaseThingHandler.collectDataFromUrl(FroniusBaseThingHandler.java:170) ~[?:?]
at org.openhab.binding.fronius.internal.handler.FroniusSymoInverterHandler.getRealtimeData(FroniusSymoInverterHandler.java:214) ~[?:?]
at org.openhab.binding.fronius.internal.handler.FroniusSymoInverterHandler.updateData(FroniusSymoInverterHandler.java:190) ~[?:?]
at org.openhab.binding.fronius.internal.handler.FroniusSymoInverterHandler.handleRefresh(FroniusSymoInverterHandler.java:64) ~[?:?]
at org.openhab.binding.fronius.internal.handler.FroniusBaseThingHandler.refresh(FroniusBaseThingHandler.java:136) ~[?:?]
at org.openhab.binding.fronius.internal.handler.FroniusBridgeHandler.lambda$0(FroniusBridgeHandler.java:130) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
Caused by: java.lang.IllegalStateException: Expected BEGIN_OBJECT but was STRING at line 1 column 1 path $
at com.google.gson.stream.JsonReader.beginObject(JsonReader.java:384) ~[?:?]
at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$Adapter.read(ReflectiveTypeAdapterFactory.java:215) ~[?:?]
... 16 more
2022-11-06 18:03:32.923 [DEBUG] [rnal.handler.FroniusBaseThingHandler] - Exception caught in refresh() for 803841959c
org.openhab.binding.fronius.internal.FroniusCommunicationException: Invalid JSON data received
at org.openhab.binding.fronius.internal.handler.FroniusBaseThingHandler.collectDataFromUrl(FroniusBaseThingHandler.java:198) ~[?:?]
Caused by: com.google.gson.JsonSyntaxException: java.lang.IllegalStateException: Expected BEGIN_OBJECT but was STRING at line 1 column 1 path $
... 11 more
... 11 more
2022-11-06 18:03:32.933 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'fronius:powerinverter:af42566023:803841959c' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Invalid JSON data received
2022-11-06 18:03:34.515 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'fronius:powerinverter:af42566023:803841959c' changed from OFFLINE (COMMUNICATION_ERROR): Invalid JSON data received to UNINITIALIZED
2022-11-06 18:03:34.532 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'fronius:powerinverter:af42566023:803841959c' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
