That device should work on 2.4 or 2.5 though…
That’s what I thought but anyhow…
191 │ Active │ 80 │ 2.5.0.201901280820 │ ZWave Binding
I’m having the same issue with this device, with exactly the same characteristic as @Andrew_Rowe. and on the same binding version: Z-Wave: Some Items remain unknown after upgrade to 2.5.0
The weird thing is, that out of my 12 Fibaro FGMS-001, 3 are appearing as Unknown Device and remain unknown (no wakeup nor time has helped since some weeks now) - From that, do I correctly conclude that the solution proposed by @Celaeno1 wouldn’t help in this case?
Kurt
Changing to a newer binding version often clears other things up. You can’t loose anything, just try!
OK… update to snapshot version did the trick!
Thank you Alex, I have marked your post as the solution
Fibaro initialized and recognized and showing multiple channels in paper UI
How funny. I bought another Fibaro unit and I’m getting the same thing. Unknown device. Ive included / excluded a few times and reset the unit. Same issue, left it over night. I’m on the 2.5 version of the binding.
It is a newer version of firmware than my working unit (3.2 works, 3.3 isnt)
Here is the XML it creates:
<node>
<homeId>0xcdf013ba</homeId>
<nodeId>24</nodeId>
<version>4</version>
<manufacturer>0x10f</manufacturer>
<deviceId>0x3002</deviceId>
<deviceType>0x801</deviceType>
<listening>false</listening>
<frequentlyListening>false</frequentlyListening>
<routing>true</routing>
<security>false</security>
<beaming>true</beaming>
<maxBaudRate>40000</maxBaudRate>
<sleepDelay>1000</sleepDelay>
<nodeInformationFrame>
<commandClass>COMMAND_CLASS_ZWAVEPLUS_INFO</commandClass>
<commandClass>COMMAND_CLASS_VERSION</commandClass>
<commandClass>COMMAND_CLASS_MANUFACTURER_SPECIFIC</commandClass>
<commandClass>COMMAND_CLASS_DEVICE_RESET_LOCALLY</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION_GRP_INFO</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION</commandClass>
<commandClass>COMMAND_CLASS_POWERLEVEL</commandClass>
<commandClass>COMMAND_CLASS_WAKE_UP</commandClass>
<commandClass>COMMAND_CLASS_BATTERY</commandClass>
<commandClass>COMMAND_CLASS_ALARM</commandClass>
<commandClass>COMMAND_CLASS_CRC_16_ENCAP</commandClass>
<commandClass>COMMAND_CLASS_CONFIGURATION</commandClass>
<commandClass>COMMAND_CLASS_SENSOR_MULTILEVEL</commandClass>
<commandClass>COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION</commandClass>
<commandClass>COMMAND_CLASS_APPLICATION_STATUS</commandClass>
<commandClass>COMMAND_CLASS_SENSOR_BINARY</commandClass>
<commandClass>COMMAND_CLASS_SENSOR_ALARM</commandClass>
<commandClass>COMMAND_CLASS_SECURITY</commandClass>
<commandClass>COMMAND_CLASS_FIRMWARE_UPDATE_MD</commandClass>
</nodeInformationFrame>
<associationGroups class="concurrent-hash-map">
<entry>
<int>1</int>
<associationGroup>
<index>1</index>
<maxNodes>0</maxNodes>
<name>Lifeline</name>
<profile1>0x0</profile1>
<profile2>0x1</profile2>
<commands>
</commands>
<associations>
<associationMember>
<node>1</node>
</associationMember>
</associations>
</associationGroup>
</entry>
<entry>
<int>2</int>
<associationGroup>
<index>2</index>
<name>Motion</name>
<profile1>0x71</profile1>
<profile2>0x7</profile2>
<commands>
<commandClass>COMMAND_CLASS_BASIC</commandClass>
</commands>
<associations/>
</associationGroup>
</entry>
<entry>
<int>3</int>
<associationGroup>
<index>3</index>
<name>Tamper</name>
<commands>
</commands>
<associations/>
</associationGroup>
</entry>
<entry>
<int>4</int>
<associationGroup>
<index>4</index>
<name>Motion BC</name>
<commands>
</commands>
<associations/>
</associationGroup>
</entry>
<entry>
<int>5</int>
<associationGroup>
<index>5</index>
<name>Tamper BC</name>
<commands>
</commands>
<associations/>
</associationGroup>
</entry>
</associationGroups>
<endpoints class="concurrent-hash-map">
<entry>
<int>0</int>
<endPoint>
<deviceClass>
<basicDeviceClass>BASIC_TYPE_ROUTING_SLAVE</basicDeviceClass>
<genericDeviceClass>GENERIC_TYPE_SENSOR_NOTIFICATION</genericDeviceClass>
<specificDeviceClass>SPECIFIC_TYPE_NOTIFICATION_SENSOR</specificDeviceClass>
</deviceClass>
<endpointId>0</endpointId>
<secureCommandClasses/>
<supportedCommandClasses class="concurrent-hash-map">
<entry>
<COMMAND__CLASS__SENSOR__ALARM>
<version>1</version>
<instances>1</instances>
<control>false</control>
<versionSupported>1</versionSupported>
<alarms>
<entry>
<alarmSensorType>GENERAL</alarmSensorType>
<alarmSensor>
<alarmType>GENERAL</alarmType>
</alarmSensor>
</entry>
</alarms>
<isGetSupported>true</isGetSupported>
<isSupportedGetSupported>true</isSupportedGetSupported>
</COMMAND__CLASS__SENSOR__ALARM>
</entry>
<entry>
<COMMAND__CLASS__WAKE__UP>
<version>2</version>
<versionSupported>2</versionSupported>
<targetNodeId>1</targetNodeId>
<interval>7200</interval>
<minInterval>1</minInterval>
<maxInterval>65535</maxInterval>
<defaultInterval>7200</defaultInterval>
<intervalStep>1</intervalStep>
</COMMAND__CLASS__WAKE__UP>
</entry>
<entry>
<COMMAND__CLASS__ALARM>
<version>5</version>
<versionSupported>5</versionSupported>
<alarms>
<entry>
<alarmType>BURGLAR</alarmType>
<alarmState>
<reportedEvents/>
<outer-class reference="../../../.."/>
</alarmState>
</entry>
</alarms>
<v1Supported>true</v1Supported>
</COMMAND__CLASS__ALARM>
</entry>
<entry>
<COMMAND__CLASS__POWERLEVEL>
<powerLevel>0</powerLevel>
<powerTimeout>0</powerTimeout>
</COMMAND__CLASS__POWERLEVEL>
</entry>
<entry>
<COMMAND__CLASS__SENSOR__MULTILEVEL>
<version>8</version>
<versionSupported>8</versionSupported>
<sensors>
<entry>
<multilevelSensorType>ACCELERATION_X</multilevelSensorType>
<multilevelSensor>
<sensorType>ACCELERATION_X</sensorType>
<initialised>true</initialised>
</multilevelSensor>
</entry>
<entry>
<multilevelSensorType>SEISMIC_INTENSITY</multilevelSensorType>
<multilevelSensor>
<sensorType>SEISMIC_INTENSITY</sensorType>
</multilevelSensor>
</entry>
<entry>
<multilevelSensorType>ACCELERATION_Z</multilevelSensorType>
<multilevelSensor>
<sensorType>ACCELERATION_Z</sensorType>
</multilevelSensor>
</entry>
<entry>
<multilevelSensorType>LUMINANCE</multilevelSensorType>
<multilevelSensor>
<sensorType>LUMINANCE</sensorType>
</multilevelSensor>
</entry>
<entry>
<multilevelSensorType>ACCELERATION_Y</multilevelSensorType>
<multilevelSensor>
<sensorType>ACCELERATION_Y</sensorType>
</multilevelSensor>
</entry>
<entry>
<multilevelSensorType>TEMPERATURE</multilevelSensorType>
<multilevelSensor>
<sensorType>TEMPERATURE</sensorType>
</multilevelSensor>
</entry>
</sensors>
</COMMAND__CLASS__SENSOR__MULTILEVEL>
</entry>
<entry>
<COMMAND__CLASS__FIRMWARE__UPDATE__MD>
<versionSupported>3</versionSupported>
</COMMAND__CLASS__FIRMWARE__UPDATE__MD>
</entry>
<entry>
<COMMAND__CLASS__SECURITY>
</COMMAND__CLASS__SECURITY>
</entry>
<entry>
<COMMAND__CLASS__MANUFACTURER__SPECIFIC>
<initSerialNumber>false</initSerialNumber>
<deviceManufacturer>271</deviceManufacturer>
<deviceType>2049</deviceType>
<deviceId>12290</deviceId>
</COMMAND__CLASS__MANUFACTURER__SPECIFIC>
</entry>
<entry>
<COMMAND__CLASS__DEVICE__RESET__LOCALLY>
</COMMAND__CLASS__DEVICE__RESET__LOCALLY>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION>
<maxGroups>5</maxGroups>
</COMMAND__CLASS__ASSOCIATION>
</entry>
<entry>
<COMMAND__CLASS__BATTERY>
<batteryLevel>100</batteryLevel>
<batteryLow>false</batteryLow>
</COMMAND__CLASS__BATTERY>
</entry>
<entry>
<COMMAND__CLASS__ZWAVEPLUS__INFO>
<zwPlusVersion>1</zwPlusVersion>
<zwPlusRole>ROLE_TYPE_SLAVE_SLEEPING_REPORTING</zwPlusRole>
<zwPlusNodeType>NODE_TYPE_ZWAVEPLUS_NODE</zwPlusNodeType>
</COMMAND__CLASS__ZWAVEPLUS__INFO>
</entry>
<entry>
<commandClass>COMMAND_CLASS_NO_OPERATION</commandClass>
<COMMAND__CLASS__NO__OPERATION>
</COMMAND__CLASS__NO__OPERATION>
</entry>
<entry>
<COMMAND__CLASS__CRC__16__ENCAP>
</COMMAND__CLASS__CRC__16__ENCAP>
</entry>
<entry>
<COMMAND__CLASS__SENSOR__BINARY>
<types/>
</COMMAND__CLASS__SENSOR__BINARY>
</entry>
<entry>
<COMMAND__CLASS__BASIC>
</COMMAND__CLASS__BASIC>
</entry>
<entry>
<COMMAND__CLASS__MULTI__CHANNEL__ASSOCIATION>
</COMMAND__CLASS__MULTI__CHANNEL__ASSOCIATION>
</entry>
<entry>
<COMMAND__CLASS__APPLICATION__STATUS>
</COMMAND__CLASS__APPLICATION__STATUS>
</entry>
<entry>
<COMMAND__CLASS__VERSION>
<libraryType>LIB_SLAVE_ENHANCED</libraryType>
<protocolVersion>4.24</protocolVersion>
<applicationVersion>3.3</applicationVersion>
<hardwareVersion>1</hardwareVersion>
</COMMAND__CLASS__VERSION>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION__GRP__INFO>
<autoSubscribeGroups>
<int>1</int>
<int>3</int>
<int>4</int>
<int>5</int>
</autoSubscribeGroups>
</COMMAND__CLASS__ASSOCIATION__GRP__INFO>
</entry>
<entry>
<COMMAND__CLASS__CONFIGURATION>
<configParameters/>
</COMMAND__CLASS__CONFIGURATION>
</entry>
</supportedCommandClasses>
</endPoint>
</entry>
</endpoints>
<nodeNeighbors/>
<lastReceived>2019-02-25 19:48:15.231 UTC</lastReceived>
And the zwave log
https://drive.google.com/open?id=1eFt9BAKMXO7azJmgh9LxHwVy782bA6Dz
yeah… it was a bugger to get this one to fly. Your above statement was what bugged me even after it finally worked
Seems theres quite a few iterations of the firmware which can cause this. I just received a new unit which requires a binding update as its a slightly different version of the FGMS001
Cheers
