When I save it, I get the following error:
14:41:50.457 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type ‘http’ of item ‘e2_chambre_rue_Hue’ could not be parsed correctly.
org.eclipse.smarthome.model.item.BindingConfigParseException: bindingConfig ‘http://192.168.0.111/api/ZzSuumxSfih6j7-mzAAxcX5xO1BsFiA4dvyp8LTY/groups/4/’ doesn’t represent a valid in-binding-configuration. A valid configuration is matched by the RegExp ‘(.?)({.})?:(?!//)(\d*):(.*)’
at org.openhab.core.binding.internal.BindingConfigReaderDelegate.processBindingConfiguration(BindingConfigReaderDelegate.java:50)[182:org.openhab.core.compat1x:2.1.0]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:325)[123:org.eclipse.smarthome.model.item:0.9.0.b5]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:297)[123:org.eclipse.smarthome.model.item:0.9.0.b5]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.processBindingConfigsFromModel(GenericItemProvider.java:182)[123:org.eclipse.smarthome.model.item:0.9.0.b5]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.modelChanged(GenericItemProvider.java:367)[123:org.eclipse.smarthome.model.item:0.9.0.b5]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.notifyListeners(ModelRepositoryImpl.java:286)[122:org.eclipse.smarthome.model.core:0.9.0.b5]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:136)[122:org.eclipse.smarthome.model.core:0.9.0.b5]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.checkFile(FolderObserver.java:234)[122:org.eclipse.smarthome.model.core:0.9.0.b5]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.processWatchEvent(FolderObserver.java:297)[122:org.eclipse.smarthome.model.core:0.9.0.b5]
at org.eclipse.smarthome.core.service.WatchQueueReader.run(WatchQueueReader.java:206)[98:org.eclipse.smarthome.core:0.9.0.b5]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_65]
I don’t understand because this url is working in a browser and this is a standard url…
I get the same error. What I miss is the transformation rule to use when obtaining a single number from the url. How can I parse the value retrieved from url “http://x.x.x.x/now” that deliver an integer?
Writing “http://192.168.1.201/now” in my browser returns realtime power usage as an integer wattage, for instance “4732”. This number I would like to present in a gauge, powerNow.
