the goal is simple, i have a door sensor. i want to be alerted by telegram and chromecast if the door is opened more than one minute and a get a reminder every 30 sec till the door will be closed
rule "door opened"
Item mqtt_sensor_door changed
if (Motion_Enable_Switch.state == OFF) return;
if(previousState == NULL) return;
if(mqtt_sensor_door.state == "CLOSED") return;
logInfo("GroupTest", "Door is opened")
Thread::sleep(20)
if(mqtt_sensor_door.state == "OPEN"){
// i never got the log above. that's the issue
logInfo("GroupTest", "Door is STILL opened")
if(Bot6_Enabled.state == ON){sendTelegram("bot6","Close the door" )}
if (VoiceOutput_Switch.state == OFF ){ say("Close the door")}
logInfo("GroupTest", "Done")
the validation of the current state seems to not working. moreover, i have some issues to structure this loop.
I assume that your door_sensor is a contact sensor in that case the states are OPEN or CLOSED, no quotes
Add some logInfo statements to find out where the rule exits…
Use a time for the first minute
We’ll deal with the repeat every 30 seconds later
I also tidied up because your indents were a mess
rule "door opened"
logInfo("GroupTest", "TEST 1")
logInfo("GroupTest", "TEST 2")
if (previousState == NULL) return;
logInfo("GroupTest", "TEST 3")
if (mqtt_sensor_door.state == CLOSED) return;
createTimer(now.plusMinutes(1), [ |
if(mqtt_sensor_door.state == OPEN) {
if(Bot6_Enabled.state == ON) {
if (VoiceOutput_Switch.state == OFF ) {
Thank you , it worked
could you help me on the loop ?
2018-09-27 15:13:47.054 [INFO ] [pse.smarthome.model.script.GroupTest] - TEST 1
2018-09-27 15:13:47.067 [INFO ] [rthome.model.script.Rule File:MOTION] - group motion
2018-09-27 15:13:47.073 [INFO ] [pse.smarthome.model.script.GroupTest] - TEST 2
2018-09-27 15:13:47.082 [INFO ] [pse.smarthome.model.script.GroupTest] - TEST 3
2018-09-27 15:13:47.088 [INFO ] [pse.smarthome.model.script.GroupTest] - Member mqtt_sensor_door to OPEN
2018-09-27 15:13:47.096 [INFO ] [pse.smarthome.model.script.GroupTest] - Door is opened
2018-09-27 15:14:10.431 [INFO ] [pse.smarthome.model.script.GroupTest] - Door is STILL opened
You need to add the following line at the TOP of your rules file:
var Timer timer = null
Then your rule becomes:
rule "door opened"
if (timer === null) {
timer = createTimer(now.plusMinutes(1), [ |
timer.reschedule(now.plusSeconds(30)) // Do it again in 30 seconds
} else {
timer = null // cancels the timer
