Let me explain what I did and maybe it helps to understand what is happening:
- I installed and configured OH2 beta 5
- I played with some rules with this beta with the Habmin panel
- As they were just tests I tried to delete them from the Habmin panel itself but as I wan’t able I deleted them manually from the files I found on my “openhab2” folder
- I checked that there are not any rule inside Habmin panel
- Then I moved to the final OH2 release just adding my /conf/ and /userdata/ folder from the beta 5
- Everything is working fine
- I started using the new Experimental Rules (pretty nice stuff, but still not documented at all)… well, I think this has nothing to do with the problems I’m experimenting
- I have just double checked that the test rules are still working but there are any Habmin panel entries nor any rule file inside my /openhab2/
Any idea what’s happening? I think I haven’t correctly deleted the old Habmin rules but now I don’t know where to look for and how to solve the issue without having to start from scratch…
Thank you
