I’m not really a noob nor am I extremely verse with openhab. I have been able to use the global cache binding to talk to IR devices and it works great (with my Itach Flex).
The problem is I am trying to read the states of a contact closure without any success. I have noticed that the binding says that sensor in and sensor notify features are not currently supported but I was hoping to find a way around this. Here is what I’ve tried so far:
Looking at the code which makes up the binding in hopes of being able to add the features. - I got lost in that java code, but that was fun, maybe a bit beyond where I am at the moment with openhab.
Using a TCP/UDP binding. - The iHelp and iTest programs (I am on Windows 10) work perfectly to confirm that the Itach Flex is communicating over my network. If I could just work out how to ‘poll’ the contact closure I could use UDP to always know the status of it. I believe this is the best option along with a rule or two to decide what to do when the state changes.
Any suggestions on this matter would be greatly appreciated.
Thanks a lot for the response. I am currently looking into it. I thought I should be using the UDP binding but HTTP really does look promising. I will let you know when I get it to work.
So far I think I don’t know how to parse the response correctly (if I am actually getting a response). I will try a few more things so I can know the right questions to ask if I don’t figure it out.
Ok so the Flex HTTP API was not as helpfull as I hoped but it did point me in the right direction. I found the Global Caché RESTful HTTP API which took me the rest of the way. I haven’t gotten polling to work yet but I am confident that I can get a working solution from here.
and finally I created a rule that runs whenever the state changes so as to update my sitemap interface.
rule “Get Device state”
Item portStatus changed
logInfo(“checkState.rules”, "State: " + portStatus.state )
if (portStatus.state==“1”)
sendCommand(MyRelay3,“ON”)
else
sendCommand(MyRelay3,“OFF”)
Of course you would have to know what ports to check, I’m checking port 3 in the example above. This was set in the http definition of contactsensor.url.
