I’m trying to setup a light to connect to google home. It is a dimmable device that has 2 channels (ON/OFF) and Brightness. These are setup as Switch and Dimmer items. They are tagged as lighting.
The show up in Google Home just fine, but i see 2 lights. #1 just has on/off function. #2 has on/off and dimmer, but the on/off doesn’t do anything. This is understandable as google is seeing the 2 as separate devices as there are 2 items.
Just wondering if there is anyway to avoid this and set it up so that i only see one ‘Light’ in google home (and dimmable light with on/off that works)?
Could you share the final configuration file parts for your solution? I read the referenced solution, but it wasn’t obvious what needed to change in my configuration.
Hi, I don’t actually have any items configured with 2 channels any more, the Shelly binding was updated so that #brightness channel can accept ON/OFF and brightness values.
