I’m new to Openhab and zwave and am having some problems pairing to my Greenwave powernode (UK) version.
I have successfully installed the Zwave.me UZB1 and paired 2 powernodes, but they are showing as unknown devices. I suspect that this is because the UK version (NS210-G-EN) is not in the DB as it looks like a device is in there.
Ok - unfortunately you’re using the release version which is going to be difficult to upgrade to the latest snapshot. It should work for this device, but these Greenwave devices have bugs that I’m trying to work around at the moment. The device should detect ok though - as a matter of interest, what happens if you restart the binding?
Ok - the database seems to be versioned - not sure if this is needed, but your device seems to show version 0 at the moment which might be the issue. Try reinitialising the device -:
What are these bugs you are working around and are they in a later version of OH?
Was it this issue which just missed the 2.0 release. Should I move to 2.1 snapshot and retest?
I have some of the Greenwave plugs as they were £20 but I find them very unreliable. The seem to reject commands sometimes and not talk at all other times. I also found them very laggy.
Just to note I have updated to the 2.1 release and the Green wave plugs are behaving much better. It can take a few attempts to bind them but once part of the network they seem to be much more reliable.
They are still a bit laggy with on/off commands compared to some Aeontec plufs but I mostly use them for electrical monitoring to trigger washing machine and tumble dryer finished notifications and they work fine
