my sitemap looks like this
sitemap default label=“Home” {
Group item=LivingRoom{
Frame label=“Reciver” icon=“receiver” {
Switch item=VSX923_Zone1Power
Switch item=VSX923_Zone1SetInputSource mappings=[06=“Yes”, 15=“AppleTV”, 22=“PlayStation”]
Slider item=VSX923_Zone1VolumeDimmer
Setpoint item=VSX923_Zone1VolumeDb minValue=-80 maxValue=0 step=1
Switch item=VSX923_Zone1Mute mappings=[ON=“Mute”, OFF=“Un-Mute”]
Text item=iPhone_Home
and i got the below errors
2019-01-04 16:56:29.409 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model ‘default.sitemap’
2019-01-04 16:56:29.516 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Group
2019-01-04 16:56:29.520 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item ‘LivingRoom’ for widget org.eclipse.smarthome.model.sitemap.Group
2019-01-04 16:56:29.523 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item ‘LivingRoom’ for widget org.eclipse.smarthome.model.sitemap.Group
2019-01-04 16:56:29.527 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item ‘LivingRoom’ for widget org.eclipse.smarthome.model.sitemap.Group
2019-01-04 16:56:56.851 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item ‘LivingRoom’ for widget org.eclipse.smarthome.model.sitemap.Group
2019-01-04 16:56:56.854 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item ‘LivingRoom’ for widget org.eclipse.smarthome.model.sitemap.Group
2019-01-04 16:56:56.858 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Group
2019-01-04 16:56:56.862 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Group
2019-01-04 16:56:56.997 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item ‘LivingRoom’ for widget org.eclipse.smarthome.model.sitemap.Group
2019-01-04 16:56:57.001 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item ‘LivingRoom’ for widget org.eclipse.smarthome.model.sitemap.Group
2019-01-04 16:56:57.005 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Group
2019-01-04 16:56:57.009 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Group
2019-01-04 16:57:27.353 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item ‘LivingRoom’ for widget org.eclipse.smarthome.model.sitemap.Group
2019-01-04 16:57:27.360 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item ‘LivingRoom’ for widget org.eclipse.smarthome.model.sitemap.Group
2019-01-04 16:57:27.365 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Group
2019-01-04 16:57:27.372 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Group
can anyone explain why i have the errors?
