Hi all,
I am setting up my OpenHAB on a RasPI 3 with the RaZberry 2 HAT and mostly Z-Wave components.
I have most of the stuff I need working. Due to some limitations of PaperUI and/or HABmin I decided to define everything in files. After setting up a Samba drive i went at it with the Eclipse Designer tool.
My Problem: I have created a group (gEGLicht) for switches and added two switches to the Group. I also added the Group as a switch to my sitemap. The switches Themselves work properly. But when i try to turn the Group on or off, nothing happens. In the karaf log I also only see, that the group Item was toggled, but the switches stay as they are.
I was under the assupmtion, that if I turn the group Item off, all switches in it should turn off as well.
Here is my items file:
//Type Identifier "Label" <icon> (group1, group2) ["tag1, "tag2"] {bindigconfig}
Switch Esszimmer_ZWSwitch1 "Esszimmerlampe" <light> (gEGLicht) ["Switchable"] {channel="zwave:device:b684c393:node7:switch_binary"}
Switch Wohnzimmer_ZWSwitch1 "Ecklampe" <light> (gEGLicht) ["Switchable"] {channel="zwave:device:b684c393:node6:switch_binary"}
//Groups
Group:Switch:OR(ON, OFF) gEGLicht "Licht im Erdgeschoss" <light> (gLicht, gErgdeschoss) ["Switchable"]
And here is my Sitemap
sitemap myhome label="Zuhause" {
Frame label="Erdgeschoss"{
Switch label="EG Licht" item=gEGLicht
Switch label="Tiffany Lampe" item=Esszimmer_ZWSwitch1 icon="light"
Switch label="Ecklampe" item=Wohnzimmer_ZWSwitch1 icon="light"
The tags are used for the Hue Emulation binding. I can toggle them via Amazon Echo. Same thing: THe light switches turn on and off, but the group switch does nothong.
If anyone can help, I would be really greateful.
Edit: I have created a switch item that can toggle both Z-Wave Switches by adding both channels to the item’s config, so this is a workaround for now. But I would still like to get the Group solution to work.
